Ana içeriğe geç
Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement
Neye ihtiyacın var
  1. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the eleven 6.5 mm screws that secure the back case using a Phillips #1 screwdriver.
  2. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 2, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 2, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to gently pry open the back cover.
  3. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 3, 1 resimden 1.
    • Gently remove the back cover from the device.
  4. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement, Battery: adım 4, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement, Battery: adım 4, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement, Battery: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, remove the piece of black tape over the battery cable connector.
  5. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 5, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 5, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 5, 3 resimden 3.
    • Remove the piece of black tape that covers the battery.
  6. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 6, 2 resimden 1. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 6, 2 resimden 2.
    • Grip the battery cable on both sides with your fingertips and gently pull it away from the port.
    • If needed, use the plastic opening tool to remove the cord from its port.
  7. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 7, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 7, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 7, 3 resimden 3.
    • Remove the two 3.5 mm screws that secure the battery using a Phillips #00 screwdriver (PH00 bit).
  8. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 8, 2 resimden 1. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 8, 2 resimden 2.
    • Carefully place your fingers under the plastic lip where the screws were removed.
    • Lift upwards to remove the battery.
    • Do not bend or puncture the lithium ion battery as it poses a fire hazard.
  9. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement, Side Ports and Buttons: adım 9, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement, Side Ports and Buttons: adım 9, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement, Side Ports and Buttons: adım 9, 3 resimden 3.
    Satın Al
    • Using tweezers, carefully grip the sensor cable by the white and red tab.
    • Using gentle pressure, remove the cable from its connection by pulling outward.
  10. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 10, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 10, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 10, 3 resimden 3.
    • Place your fingernail underneath the locking black tab of the ZIF connector on the USB/Side Port Board and pry it upwards to release the cable.
  11. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 11, 2 resimden 1. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 11, 2 resimden 2.
    • Remove the ribbon interconnect cable from the connector.
  12. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 12, 2 resimden 1. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 12, 2 resimden 2.
    • Remove the two 3.5mm screws that secure the side ports using a Phillips #00 screwdriver (PH00 bit).
  13. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 13, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 13, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: adım 13, 3 resimden 3.
    • Using tweezers, gently grip the middle of the board that contains the side ports and carefully pull out to remove it.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 1,368
