Ana içeriğe geç
Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement
Neye ihtiyacın var
  1. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Battery: adım 1, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Battery: adım 1, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Battery: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, remove the piece of black tape over the battery cable connector.
  2. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 2, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 2, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 2, 3 resimden 3.
    • Remove the piece of black tape that covers the battery.
  3. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 3, 2 resimden 1. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 3, 2 resimden 2.
    • Grip the battery cable on both sides with your fingertips and gently pull it away from the port.
    • If needed, use the plastic opening tool to remove the cord from its port.
  4. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 4, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 4, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 4, 3 resimden 3.
    • Remove the two 3.5 mm screws that secure the battery using a Phillips #00 screwdriver (PH00 bit).
  5. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 5, 2 resimden 1. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 5, 2 resimden 2.
    • Carefully place your fingers under the plastic lip where the screws were removed.
    • Lift upwards to remove the battery.
    • Do not bend or puncture the lithium ion battery as it poses a fire hazard.
  6. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Wireless (WiFi) Card: adım 6, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Wireless (WiFi) Card: adım 6, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Wireless (WiFi) Card: adım 6, 3 resimden 3.
    Satın Al
    • Using tweezers, remove the sticker that covers the connection between the wireless card and motherboard.
  7. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 7, 2 resimden 1. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 7, 2 resimden 2.
    • Remove the 6.5 mm screw that secures the wireless card using a Phillips #00 screwdriver (PH00 bit).
  8. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 8, 2 resimden 1. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 8, 2 resimden 2.
    • Gently pull the wireless card away from the motherboard.
  9. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 9, 3 resimden 1. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 9, 3 resimden 2. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 9, 3 resimden 3.
    • Using your fingers, carefully pull the white wire upwards, removing it from the terminal of the wireless card.
  10. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 10, 2 resimden 1. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 10, 2 resimden 2.
    • Repeat the previous step but this time for the black wire.
  11. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 11, 2 resimden 1. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: adım 11, 2 resimden 2.
    • Remove the wireless (WiFi) card from the laptop.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 33
Her zaman: 1,535
