Ana içeriğe geç
Acer Spin 7 SP714-51 Solid State Drive Replacement
Neye ihtiyacın var
  1. Acer Spin 7 SP714-51 Solid State Drive Replacement, Solid State Drive: adım 1, 1 resimden 1.
    • Turn the laptop so that the back cover is visible and facing you. Make sure it is on a flat surface such as a table.
    • Use a Phillips #0 screwdriver to remove the 6 mm screws along the edge of the bottom cover.
  2. Acer Spin 7 SP714-51 Solid State Drive Replacement: adım 2, 1 resimden 1.
    • You can now remove the back panel using your fingers or a spudger.
  3. Acer Spin 7 SP714-51 Solid State Drive Replacement: adım 3, 1 resimden 1.
    • Carefully unplug the battery connector so the laptop is safer to work with.
    • Make sure you pull it straight back.
  4. Acer Spin 7 SP714-51 Solid State Drive Replacement: adım 4, 1 resimden 1.
    • Once the back is open and the battery is disconnected, you should be able to see the SSD on the top right of the laptop if oriented as seen in the photo.
    • The removal of the SSD should be simple as there is only one 6 mm PH0 Phillips screw holding it in place.
    • Once the screw is removed, you may safely remove the SSD and replace it with your new one.
Sonuç
Zach Desrosiers
565 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-3, Sinclaire Spring 2022 UMass Dartmouth, Team 7-3, Sinclaire Spring 2022 üyesi
UMASSD-SINCLAIRE-S22S7G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 37
Her zaman: 1,030
