Ana içeriğe geç
Acer Swift 3 2022 Screen Replacement
Neye ihtiyacın var
    1. Acer Swift 3 2022 Screen Replacement, Bottom Cover: adım 1, 1 resimden 1.
      • Be sure to power off the laptop before starting.
      • Flip the device over so the bottom panel is facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Acer Swift 3 2022 Screen Replacement: adım 2, 2 resimden 1. Acer Swift 3 2022 Screen Replacement: adım 2, 2 resimden 2.
      • Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Acer Swift 3 2022 Screen Replacement: adım 3, 1 resimden 1.
      • Use the iFixit opening tool to pry open the back of the device.
      • Remove the bottom cover from the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Acer Swift 3 2022 Screen Replacement, How to Unplug the Battery: adım 4, 3 resimden 1. Acer Swift 3 2022 Screen Replacement, How to Unplug the Battery: adım 4, 3 resimden 2. Acer Swift 3 2022 Screen Replacement, How to Unplug the Battery: adım 4, 3 resimden 3.
      • Peel back the strip of black tape.
      FixBot'a Sor
      Yorum Ekle
    2. Acer Swift 3 2022 Screen Replacement: adım 5, 2 resimden 1. Acer Swift 3 2022 Screen Replacement: adım 5, 2 resimden 2.
      • Unplug the group of wires by pulling the white plastic piece towards yourself.
      • Be careful, this piece can be easily damaged.
      FixBot'a Sor
      Yorum Ekle
    1. Acer Swift 3 2022 Screen Replacement, Screen: adım 6, 3 resimden 1. Acer Swift 3 2022 Screen Replacement, Screen: adım 6, 3 resimden 2. Acer Swift 3 2022 Screen Replacement, Screen: adım 6, 3 resimden 3.
      • Remove the EDP Cable located on the top right by pushing away from you.
      FixBot'a Sor
      Yorum Ekle
    2. Acer Swift 3 2022 Screen Replacement: adım 7, 3 resimden 1. Acer Swift 3 2022 Screen Replacement: adım 7, 3 resimden 2. Acer Swift 3 2022 Screen Replacement: adım 7, 3 resimden 3.
      • Remove the four 4.5 mm screws on the metal plates located on the top left and right hand corner using the JIS #1 screwdriver.
      • Flip up the metal plates.
      • The metal plates will be tight/hard to move.
      FixBot'a Sor
      Yorum Ekle
    3. Acer Swift 3 2022 Screen Replacement: adım 8, 1 resimden 1.
      • Open computer to a 90 degree angle by lifting the keyboard and sliding it out.
      • Place keyboard to the side so the screen is face up and the only thing in front of you.
      FixBot'a Sor
      Yorum Ekle
    4. Acer Swift 3 2022 Screen Replacement: adım 9, 3 resimden 1. Acer Swift 3 2022 Screen Replacement: adım 9, 3 resimden 2. Acer Swift 3 2022 Screen Replacement: adım 9, 3 resimden 3.
      • Insert the spudger between the computer screen and the black bezel.
      • Slide around the whole perimeter of screen.
      • Peel the bezel off.
      FixBot'a Sor
      Yorum Ekle
    5. Acer Swift 3 2022 Screen Replacement: adım 10, 3 resimden 1. Acer Swift 3 2022 Screen Replacement: adım 10, 3 resimden 2. Acer Swift 3 2022 Screen Replacement: adım 10, 3 resimden 3.
      • Disconnect the other end of the EDP Cable located next to the camera with the spudger.
      FixBot'a Sor
      Yorum Ekle
    6. Acer Swift 3 2022 Screen Replacement: adım 11, 3 resimden 1. Acer Swift 3 2022 Screen Replacement: adım 11, 3 resimden 2. Acer Swift 3 2022 Screen Replacement: adım 11, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Using the curved, fine-tipped tweezers, unstick the tape from the top of the case.
      • Once the tape is unstuck, pinch it with the tweezers and pull in the opposite direction.
      • Repeat on the other side.
      • The tape will stretch. You might have to regrip it.
      • You may only do this once. The tape will no longer be effective.
      FixBot'a Sor
      Yorum Ekle
    7. Acer Swift 3 2022 Screen Replacement: adım 12, 1 resimden 1.
      • Remove screen.
      • There will be some wires connected to the bottom of the screen. Pull them out carefully with the screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Anna Miller
927 İtibar
6 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-2, McMurrin Fall 2022 Utah Tech University, Team 1-2, McMurrin Fall 2022 üyesi
UTAHTECH-MCMURRIN-F22S1G2
2 Üyeler
54 adet Kılavuz yazıldı
1Rehber Yorum
really good i just followed the instructions and it was easy to do.
Sanchoi Dacres - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 36
Son 30 gün: 141
Her zaman: 5,265
