Ana içeriğe geç
Acer Swift 3 2022 Screen Replacement
Neye ihtiyacın var
  1. Acer Swift 3 2022 Screen Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Be sure to power off the laptop before starting.
    • Flip the device over so the bottom panel is facing up.
  2. Acer Swift 3 2022 Screen Replacement: adım 2, 2 resimden 1. Acer Swift 3 2022 Screen Replacement: adım 2, 2 resimden 2.
    • Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
  3. Acer Swift 3 2022 Screen Replacement: adım 3, 1 resimden 1.
    • Use the iFixit opening tool to pry open the back of the device.
    • Remove the bottom cover from the laptop.
  4. Acer Swift 3 2022 Screen Replacement, How to Unplug the Battery: adım 4, 3 resimden 1. Acer Swift 3 2022 Screen Replacement, How to Unplug the Battery: adım 4, 3 resimden 2. Acer Swift 3 2022 Screen Replacement, How to Unplug the Battery: adım 4, 3 resimden 3.
    • Peel back the strip of black tape.
  5. Acer Swift 3 2022 Screen Replacement: adım 5, 2 resimden 1. Acer Swift 3 2022 Screen Replacement: adım 5, 2 resimden 2.
    • Unplug the group of wires by pulling the white plastic piece towards yourself.
    • Be careful, this piece can be easily damaged.
  6. Acer Swift 3 2022 Screen Replacement, Screen: adım 6, 3 resimden 1. Acer Swift 3 2022 Screen Replacement, Screen: adım 6, 3 resimden 2. Acer Swift 3 2022 Screen Replacement, Screen: adım 6, 3 resimden 3.
    • Remove the EDP Cable located on the top right by pushing away from you.
  7. Acer Swift 3 2022 Screen Replacement: adım 7, 3 resimden 1. Acer Swift 3 2022 Screen Replacement: adım 7, 3 resimden 2. Acer Swift 3 2022 Screen Replacement: adım 7, 3 resimden 3.
    • Remove the four 4.5 mm screws on the metal plates located on the top left and right hand corner using the JIS #1 screwdriver.
    • Flip up the metal plates.
    • The metal plates will be tight/hard to move.
  8. Acer Swift 3 2022 Screen Replacement: adım 8, 1 resimden 1.
    • Open computer to a 90 degree angle by lifting the keyboard and sliding it out.
    • Place keyboard to the side so the screen is face up and the only thing in front of you.
  9. Acer Swift 3 2022 Screen Replacement: adım 9, 3 resimden 1. Acer Swift 3 2022 Screen Replacement: adım 9, 3 resimden 2. Acer Swift 3 2022 Screen Replacement: adım 9, 3 resimden 3.
    • Insert the spudger between the computer screen and the black bezel.
    • Slide around the whole perimeter of screen.
    • Peel the bezel off.
  10. Acer Swift 3 2022 Screen Replacement: adım 10, 3 resimden 1. Acer Swift 3 2022 Screen Replacement: adım 10, 3 resimden 2. Acer Swift 3 2022 Screen Replacement: adım 10, 3 resimden 3.
    • Disconnect the other end of the EDP Cable located next to the camera with the spudger.
  11. Acer Swift 3 2022 Screen Replacement: adım 11, 3 resimden 1. Acer Swift 3 2022 Screen Replacement: adım 11, 3 resimden 2. Acer Swift 3 2022 Screen Replacement: adım 11, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using the curved, fine-tipped tweezers, unstick the tape from the top of the case.
    • Once the tape is unstuck, pinch it with the tweezers and pull in the opposite direction.
    • Repeat on the other side.
    • The tape will stretch. You might have to regrip it.
    • You may only do this once. The tape will no longer be effective.
  12. Acer Swift 3 2022 Screen Replacement: adım 12, 1 resimden 1.
    • Remove screen.
    • There will be some wires connected to the bottom of the screen. Pull them out carefully with the screen.
Sonuç
Anna Miller
888 İtibar
6 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-2, McMurrin Fall 2022 Utah Tech University, Team 1-2, McMurrin Fall 2022 üyesi
UTAHTECH-MCMURRIN-F22S1G2
2 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 24
Son 30 gün: 107
Her zaman: 3,461
