Ana içeriğe geç
Acer Swift 3 2022 Speakers Replacement
Neye ihtiyacın var
  1. Acer Swift 3 2022 Speakers Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Be sure to power off the laptop before starting.
    • Flip the device over so the bottom panel is facing up.
  2. Acer Swift 3 2022 Speakers Replacement: adım 2, 2 resimden 1. Acer Swift 3 2022 Speakers Replacement: adım 2, 2 resimden 2.
    • Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
  3. Acer Swift 3 2022 Speakers Replacement: adım 3, 1 resimden 1.
    • Use the iFixit opening tool to pry open the back of the device.
    • Remove the bottom cover from the laptop.
  4. Acer Swift 3 2022 Speakers Replacement, How to Unplug the Battery: adım 4, 3 resimden 1. Acer Swift 3 2022 Speakers Replacement, How to Unplug the Battery: adım 4, 3 resimden 2. Acer Swift 3 2022 Speakers Replacement, How to Unplug the Battery: adım 4, 3 resimden 3.
    • Peel back the strip of black tape.
  5. Acer Swift 3 2022 Speakers Replacement: adım 5, 2 resimden 1. Acer Swift 3 2022 Speakers Replacement: adım 5, 2 resimden 2.
    • Unplug the group of wires by pulling the white plastic piece towards yourself.
    • Be careful, this piece can be easily damaged.
  6. Acer Swift 3 2022 Speakers Replacement, Speakers: adım 6, 2 resimden 1. Acer Swift 3 2022 Speakers Replacement, Speakers: adım 6, 2 resimden 2.
    • With the iFixit opening tool or your nail, gently lift the speaker up near the bottom attachment site.
  7. Acer Swift 3 2022 Speakers Replacement: adım 7, 1 resimden 1.
    • Pinch the end of the speaker to gently slide the the other end out towards you while still being attached to the white plastic piece.
  8. Acer Swift 3 2022 Speakers Replacement: adım 8, 2 resimden 1. Acer Swift 3 2022 Speakers Replacement: adım 8, 2 resimden 2.
    • Remove tape overlaying the wires.
  9. Acer Swift 3 2022 Speakers Replacement: adım 9, 2 resimden 1. Acer Swift 3 2022 Speakers Replacement: adım 9, 2 resimden 2.
    • With your two fingernails, place them on both sides of the upside-down "T" and pull towards yourself.
    • Be careful removing this piece; it can be damaged by removing it at a bad angle. Pull straight back.
  10. Acer Swift 3 2022 Speakers Replacement: adım 10, 1 resimden 1.
    • Remove the speaker.
    • Repeat for the other side.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Anna Miller
888 İtibar
6 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-2, McMurrin Fall 2022 Utah Tech University, Team 1-2, McMurrin Fall 2022 üyesi
UTAHTECH-MCMURRIN-F22S1G2
2 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 49
Her zaman: 933
