Ana içeriğe geç
Acer Swift 3 2022 Touchpad Replacement
Neye ihtiyacın var
  1. Acer Swift 3 2022 Touchpad Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Be sure to power off the laptop before starting.
    • Flip the device over so the bottom panel is facing up.
  2. Acer Swift 3 2022 Touchpad Replacement: adım 2, 2 resimden 1. Acer Swift 3 2022 Touchpad Replacement: adım 2, 2 resimden 2.
    • Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
  3. Acer Swift 3 2022 Touchpad Replacement: adım 3, 1 resimden 1.
    • Use the iFixit opening tool to pry open the back of the device.
    • Remove the bottom cover from the laptop.
  4. Acer Swift 3 2022 Touchpad Replacement, Battery: adım 4, 2 resimden 1. Acer Swift 3 2022 Touchpad Replacement, Battery: adım 4, 2 resimden 2.
    • Peel back the strip of black tape.
  5. Acer Swift 3 2022 Touchpad Replacement: adım 5, 3 resimden 1. Acer Swift 3 2022 Touchpad Replacement: adım 5, 3 resimden 2. Acer Swift 3 2022 Touchpad Replacement: adım 5, 3 resimden 3.
    • Unplug the group of wires by pulling the white plastic piece towards yourself.
    • Be careful, this piece can be easily damaged.
  6. Acer Swift 3 2022 Touchpad Replacement: adım 6, 2 resimden 1. Acer Swift 3 2022 Touchpad Replacement: adım 6, 2 resimden 2.
    • Remove the two 5 mm screws on the sides of the battery using a TR6 Torx screwdriver.
  7. Acer Swift 3 2022 Touchpad Replacement: adım 7, 1 resimden 1.
    • Remove battery.
  8. Acer Swift 3 2022 Touchpad Replacement, Touchpad: adım 8, 1 resimden 1.
    • Before disassembly, place a sheet of paper or cloth material between the touchpad and the screen.
  9. Acer Swift 3 2022 Touchpad Replacement: adım 9, 2 resimden 1. Acer Swift 3 2022 Touchpad Replacement: adım 9, 2 resimden 2.
    • Using the iFixit opening tool, flip up the black plastic retaining flap holding the white ribbon cable.
    • It's like popping open a coke can!
  10. Acer Swift 3 2022 Touchpad Replacement: adım 10, 1 resimden 1.
    • Pull the ribbon cable out.
  11. Acer Swift 3 2022 Touchpad Replacement: adım 11, 2 resimden 1. Acer Swift 3 2022 Touchpad Replacement: adım 11, 2 resimden 2.
    • Pull the black flap of film up to identify the two screws.
    • Remove the two 2 mm screws using a JIS #1 screwdriver.
  12. Acer Swift 3 2022 Touchpad Replacement: adım 12, 1 resimden 1.
    • Take out the touchpad.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Anna Miller
888 İtibar
6 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-2, McMurrin Fall 2022 Utah Tech University, Team 1-2, McMurrin Fall 2022 üyesi
UTAHTECH-MCMURRIN-F22S1G2
2 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 56
Her zaman: 1,267
