Ana içeriğe geç
Acer Swift X N20C12 Display Assembly Replacement
Neye ihtiyacın var
  1. Acer Swift X N20C12 Display Assembly Replacement, Lower Case: adım 1, 1 resimden 1.
    • Use a Torx T5 screwdriver to remove the eleven screws that secure the lower case.
  2. Acer Swift X N20C12 Display Assembly Replacement: adım 2, 1 resimden 1.
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the pick around the perimeter while prying until the lower case releases.
    • Remove the lower case.
  3. Acer Swift X N20C12 Display Assembly Replacement, Display Assembly: adım 3, 2 resimden 1. Acer Swift X N20C12 Display Assembly Replacement, Display Assembly: adım 3, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the 5.5 mm screws securing the hinges.
    • Disconnect the display cable.
  4. Acer Swift X N20C12 Display Assembly Replacement: adım 4, 1 resimden 1.
    • Lift and remove the display assembly.
Sonuç
Abrar
471 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-2, Pee Fall 2023 Gateway, Team 1-2, Pee Fall 2023 üyesi
GCC-PEE-F23S1G2
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 20
Her zaman: 131
