Ana içeriğe geç
Acer Swift X N20C12 Fan Replacement
Neye ihtiyacın var
  1. Acer Swift X N20C12 Fan Replacement, Lower Case: adım 1, 1 resimden 1.
    • Use a Torx T5 screwdriver to remove the eleven screws that secure the lower case.
  2. Acer Swift X N20C12 Fan Replacement: adım 2, 1 resimden 1.
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the pick around the perimeter while prying until the lower case releases.
    • Remove the lower case.
  3. Acer Swift X N20C12 Fan Replacement, Fan: adım 3, 1 resimden 1.
    • Use a Phillips # 1 screwdriver to remove the two 5.9 mm screws that secure the fan.
  4. Acer Swift X N20C12 Fan Replacement: adım 4, 2 resimden 1. Acer Swift X N20C12 Fan Replacement: adım 4, 2 resimden 2.
    • Grasp the white fan connector and pull it directly out of its socket.
    • Lift the fan out of the chassis.
Sonuç
Abrar
472 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-2, Pee Fall 2023 Gateway, Team 1-2, Pee Fall 2023 üyesi
GCC-PEE-F23S1G2
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 175
