Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Accessing many components on the Acer TravelMate P653-V-6882 requires you to remove the base door first. For example if you need to access the RAM module, WLAN module or HDD in your Acer TravelMate P653-V-6882, or if you want replace other internals, you are required to remove the base door.
Here is our guide on how to remove the base door for the Acer TravelMate P653-V-6882 safely!
Parçalar
Hiçbir parça belirtilmedi.
  1. Turn the computer over so the base is facing up. Slide the battery lock to unlock position.
    • Turn the computer over so the base is facing up.
    • Slide the battery lock to unlock position.
  2. Slide the battery release latch to the right.
    • Slide the battery release latch to the right.
    • The battery pack will pop out.
  3. Lift the battery up.
    • Lift the battery up.
    • Pull out the battery.
  4. Remove the five 7mm Phillips #1 screws.
    • Remove the five 7mm Phillips #1 screws.
  5. Use the opening tool to separate base door from the bottom of the laptop.
    • Use the opening tool to separate base door from the bottom of the laptop.
    • Be careful not to bend or crack the plastic back cover.
  6. Gently pry open the base door by pushing up. Pull out the base door.
    • Gently pry open the base door by pushing up.
    • Pull out the base door.
Sonuç
Daniel Popovic
961 İtibar
7 adet Kılavuz yazıldı
Takım
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 76
