Ana içeriğe geç
Acer TravelMate P653-V-6882 DC Input Replacement
Neye ihtiyacın var
  1. Acer TravelMate P653-V-6882 DC Input Replacement, Battery Pack: adım 1, 2 resimden 1. Acer TravelMate P653-V-6882 DC Input Replacement, Battery Pack: adım 1, 2 resimden 2.
    • Turn the computer over so the base is facing up.
    • Slide the battery lock to unlock position.
  2. Acer TravelMate P653-V-6882 DC Input Replacement: adım 2, 1 resimden 1.
    • Slide the battery release latch to the right.
    • The battery pack will pop out.
  3. Acer TravelMate P653-V-6882 DC Input Replacement: adım 3, 1 resimden 1.
    • Lift the battery up.
    • Pull out the battery.
  4. Acer TravelMate P653-V-6882 DC Input Replacement, ODD Module: adım 4, 1 resimden 1.
    • Slide the ODD module latch down.
    • The ODD module will pop out.
  5. Acer TravelMate P653-V-6882 DC Input Replacement: adım 5, 1 resimden 1.
    • Remove the ODD module.
  6. Acer TravelMate P653-V-6882 DC Input Replacement, Base Door: adım 6, 1 resimden 1.
    • Remove the five 7mm Phillips #1 screws.
  7. Acer TravelMate P653-V-6882 DC Input Replacement: adım 7, 1 resimden 1.
    • Use the opening tool to separate base door from the bottom of the laptop.
    • Be careful not to bend or crack the plastic back cover.
  8. Acer TravelMate P653-V-6882 DC Input Replacement: adım 8, 2 resimden 1. Acer TravelMate P653-V-6882 DC Input Replacement: adım 8, 2 resimden 2.
    • Gently pry open the base door by pushing up.
    • Pull out the base door.
  9. Acer TravelMate P653-V-6882 DC Input Replacement, Keyboard: adım 9, 1 resimden 1.
    • Remove the two 7mm Phillips #1 screws.
  10. Acer TravelMate P653-V-6882 DC Input Replacement: adım 10, 1 resimden 1.
    • Flip the laptop so that the underside is now facing the bottom.
    • Open the LCD panel.
    • Use the flat end of a spudger to push in the six latches.
    • Be careful not to bend or crack the keyboard.
  11. Acer TravelMate P653-V-6882 DC Input Replacement: adım 11, 1 resimden 1.
    • When the latches are pushed in, the keyboard will pop out.
    • Gently pry up the keyboard.
  12. Acer TravelMate P653-V-6882 DC Input Replacement: adım 12, 1 resimden 1.
    • Slide the keyboard forward to access the keyboard cable.
    • Flip the connector latch up to open it.
    • Pull out the keyboard cable gently.
    • Be careful not to damage the connector.
  13. Acer TravelMate P653-V-6882 DC Input Replacement, Mainboard: adım 13, 3 resimden 1. Acer TravelMate P653-V-6882 DC Input Replacement, Mainboard: adım 13, 3 resimden 2. Acer TravelMate P653-V-6882 DC Input Replacement, Mainboard: adım 13, 3 resimden 3.
    • Turn the computer over, open the LCD panel, and find the smart card cable connector.
    • Open the smart card cable connector latch.
    • Disconnect the cable.
  14. Acer TravelMate P653-V-6882 DC Input Replacement: adım 14, 3 resimden 1. Acer TravelMate P653-V-6882 DC Input Replacement: adım 14, 3 resimden 2. Acer TravelMate P653-V-6882 DC Input Replacement: adım 14, 3 resimden 3.
    • Find the power button launch board cable connector.
    • Open the power button launch board cable connector latch.
  15. Acer TravelMate P653-V-6882 DC Input Replacement: adım 15, 3 resimden 1. Acer TravelMate P653-V-6882 DC Input Replacement: adım 15, 3 resimden 2. Acer TravelMate P653-V-6882 DC Input Replacement: adım 15, 3 resimden 3.
    • Find the touchpad and fingerprint board cable connector.
    • Open the touchpad and fingerprint board cable connector’s latches.
    • Disconnect the cables.
  16. Acer TravelMate P653-V-6882 DC Input Replacement: adım 16, 1 resimden 1.
    • Using the #1 Phillips screwdriver, remove the two screws.
  17. Acer TravelMate P653-V-6882 DC Input Replacement: adım 17, 1 resimden 1.
    • Flip the laptop over so that the underside is facing up.
    • Remove the twelve 7mm Phillips #1 screws.
    • Remove the five 3mm Phillips #1 screws.
    • Disconnect the cables connecting to the WLAN module.
  18. Acer TravelMate P653-V-6882 DC Input Replacement: adım 18, 3 resimden 1. Acer TravelMate P653-V-6882 DC Input Replacement: adım 18, 3 resimden 2. Acer TravelMate P653-V-6882 DC Input Replacement: adım 18, 3 resimden 3.
    • Locate the small gaps between the upper cover and lower case on the left and right side of the laptop.
    • Insert the opening tool into each gap to separate the one from the other.
    • Once the upper cover is separated, lift it from the lower case.
    • Be careful not to damage the upper and lower case while removing.
  19. Acer TravelMate P653-V-6882 DC Input Replacement: adım 19, 3 resimden 1. Acer TravelMate P653-V-6882 DC Input Replacement: adım 19, 3 resimden 2. Acer TravelMate P653-V-6882 DC Input Replacement: adım 19, 3 resimden 3.
    • Detach the transparent tape securing the LCD cable.
    • Disconnect the LCD cable from the mainboard.
    • Be careful not to damage the LCD cable connector.
  20. Acer TravelMate P653-V-6882 DC Input Replacement: adım 20, 3 resimden 1. Acer TravelMate P653-V-6882 DC Input Replacement: adım 20, 3 resimden 2. Acer TravelMate P653-V-6882 DC Input Replacement: adım 20, 3 resimden 3.
    • Detach the black tape covering the microphone cable.
    • Disconnect the microphone cable from the mainboard.
  21. Acer TravelMate P653-V-6882 DC Input Replacement: adım 21, 3 resimden 1. Acer TravelMate P653-V-6882 DC Input Replacement: adım 21, 3 resimden 2. Acer TravelMate P653-V-6882 DC Input Replacement: adım 21, 3 resimden 3.
    • Open the USB board cable's connector latches.
    • Be careful not to damage the connectors.
  22. Acer TravelMate P653-V-6882 DC Input Replacement: adım 22, 3 resimden 1. Acer TravelMate P653-V-6882 DC Input Replacement: adım 22, 3 resimden 2. Acer TravelMate P653-V-6882 DC Input Replacement: adım 22, 3 resimden 3.
    • Disconnect the left speaker cable from the mainboard.
  23. Acer TravelMate P653-V-6882 DC Input Replacement: adım 23, 1 resimden 1.
    • Remove the one 7mm Phillips #1 screw.
  24. Acer TravelMate P653-V-6882 DC Input Replacement: adım 24, 2 resimden 1. Acer TravelMate P653-V-6882 DC Input Replacement: adım 24, 2 resimden 2.
    • Lift the mainboard at an angle and gently turn it on its side.
    • Disconnect the LAN cable from the mainboard.
  25. Acer TravelMate P653-V-6882 DC Input Replacement, DC Input: adım 25, 1 resimden 1.
    • Disconnect the DC input cable from the mainboard.
Sonuç
Daniel Popovic
985 İtibar
7 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 229
