Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Sometimes the RAM in a device will slow down over time. If your Acer TravelMate P653-V-6882 is being exceptionally slow, you may need to replace the RAM. This will help your device function better and increase its ability to multi task.
Ensure that the device is fully powered off before following the steps below.
Parçalar
Hiçbir parça belirtilmedi.
  1. Turn the computer over so the base is facing up. Slide the battery lock to unlock position.
    • Turn the computer over so the base is facing up.
    • Slide the battery lock to unlock position.
  2. Slide the battery release latch to the right.
    • Slide the battery release latch to the right.
    • The battery pack will pop out.
  3. Lift the battery up.
    • Lift the battery up.
    • Pull out the battery.
  4. Remove the five 7mm Phillips #1 screws.
    • Remove the five 7mm Phillips #1 screws.
  5. Use the opening tool to separate base door from the bottom of the laptop.
    • Use the opening tool to separate base door from the bottom of the laptop.
    • Be careful not to bend or crack the plastic back cover.
  6. Gently pry open the base door by pushing up. Pull out the base door.
    • Gently pry open the base door by pushing up.
    • Pull out the base door.
  7. Locate the two RAM sticks on the bottom of the laptop.
    • Locate the two RAM sticks on the bottom of the laptop.
  8. Pinch the two metal pieces holding the RAM sticks in place outwards. Holding the sides of the RAM, slide the RAM sticks out. Be careful not to touch the gold connection pins on the RAM sticks, as this could damage the RAM
    • Pinch the two metal pieces holding the RAM sticks in place outwards.
    • Holding the sides of the RAM, slide the RAM sticks out.
    • Be careful not to touch the gold connection pins on the RAM sticks, as this could damage the RAM
Sonuç
Basel Kandil
85 İtibar
1 Kılavuz yazıldı
Takım
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 49
