Ana içeriğe geç
Acer TravelMate TMB115-M-C99B Motherboard Replacement
Neye ihtiyacın var
  1. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer TravelMate TMB115-M-C99B Motherboard Replacement: adım 2, 3 resimden 1. Acer TravelMate TMB115-M-C99B Motherboard Replacement: adım 2, 3 resimden 2. Acer TravelMate TMB115-M-C99B Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the thirteen 6mm Phillips screws using the #0 screwdriver.
    • Remove the back of the laptop.
  3. Acer TravelMate TMB115-M-C99B Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the two 7mm Phillips screws from the battery using the #0 screwdriver.
  4. Acer TravelMate TMB115-M-C99B Motherboard Replacement: adım 4, 2 resimden 1. Acer TravelMate TMB115-M-C99B Motherboard Replacement: adım 4, 2 resimden 2.
    • Unplug the battery from the motherboard.
  5. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Hard Drive: adım 5, 3 resimden 1. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Hard Drive: adım 5, 3 resimden 2. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Hard Drive: adım 5, 3 resimden 3.
    • Carefully disconnect the hard drive from the motherboard.
  6. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Motherboard: adım 6, 1 resimden 1.
    • Disconnect the two wires from the Wi-Fi interface.
  7. Acer TravelMate TMB115-M-C99B Motherboard Replacement: adım 7, 2 resimden 1. Acer TravelMate TMB115-M-C99B Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove one 6mm Phillips screw from the Wi-Fi interface using the #0 screwdriver.
  8. Acer TravelMate TMB115-M-C99B Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the Wi-Fi interface from the motherboard.
  9. Acer TravelMate TMB115-M-C99B Motherboard Replacement: adım 9, 2 resimden 1. Acer TravelMate TMB115-M-C99B Motherboard Replacement: adım 9, 2 resimden 2.
    • Remove the eight 7mm Phillips screws from the motherboard using the #0 screwdriver.
  10. Acer TravelMate TMB115-M-C99B Motherboard Replacement: adım 10, 2 resimden 1. Acer TravelMate TMB115-M-C99B Motherboard Replacement: adım 10, 2 resimden 2.
    • Remove the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Melissa Martinez
279 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G5, White Winter 2019 Cal Poly, Team S1-G5, White Winter 2019 üyesi
CPSU-WHITE-W19S1G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 531
