Ana içeriğe geç
Acer TravelMate TMB115-M-C99B Screen Replacement
Neye ihtiyacın var
  1. Acer TravelMate TMB115-M-C99B Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer TravelMate TMB115-M-C99B Screen Replacement: adım 2, 3 resimden 1. Acer TravelMate TMB115-M-C99B Screen Replacement: adım 2, 3 resimden 2. Acer TravelMate TMB115-M-C99B Screen Replacement: adım 2, 3 resimden 3.
    • Remove the thirteen 6mm Phillips screws using the #0 screwdriver.
    • Remove the back of the laptop.
  3. Acer TravelMate TMB115-M-C99B Screen Replacement: adım 3, 1 resimden 1.
    • Remove the two 7mm Phillips screws from the battery using the #0 screwdriver.
  4. Acer TravelMate TMB115-M-C99B Screen Replacement: adım 4, 2 resimden 1. Acer TravelMate TMB115-M-C99B Screen Replacement: adım 4, 2 resimden 2.
    • Unplug the battery from the motherboard.
  5. Acer TravelMate TMB115-M-C99B Screen Replacement, Screen: adım 5, 2 resimden 1. Acer TravelMate TMB115-M-C99B Screen Replacement, Screen: adım 5, 2 resimden 2.
    • Use the metal spudger to pry open the front plastic cover of the screen.
  6. Acer TravelMate TMB115-M-C99B Screen Replacement: adım 6, 3 resimden 1. Acer TravelMate TMB115-M-C99B Screen Replacement: adım 6, 3 resimden 2. Acer TravelMate TMB115-M-C99B Screen Replacement: adım 6, 3 resimden 3.
    • Take off the front plastic cover then remove four 6mm Phillips screws using the #0 screwdriver.
  7. Acer TravelMate TMB115-M-C99B Screen Replacement: adım 7, 2 resimden 1. Acer TravelMate TMB115-M-C99B Screen Replacement: adım 7, 2 resimden 2.
    • Flip the screen and disconnect the port.
  8. Acer TravelMate TMB115-M-C99B Screen Replacement: adım 8, 1 resimden 1.
    • Remove the screen.
Sonuç
Melissa Martinez
279 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G5, White Winter 2019 Cal Poly, Team S1-G5, White Winter 2019 üyesi
CPSU-WHITE-W19S1G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 469
