Ana içeriğe geç
Acer TravelMate TMB115-M-C99B Touchpad Replacement
Neye ihtiyacın var
  1. Acer TravelMate TMB115-M-C99B Touchpad Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 2, 3 resimden 1. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 2, 3 resimden 2. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 2, 3 resimden 3.
    • Remove the thirteen 6mm Phillips screws using the #0 screwdriver.
    • Remove the back of the laptop.
  3. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 3, 1 resimden 1.
    • Remove the two 7mm Phillips screws from the battery using the #0 screwdriver.
  4. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 4, 2 resimden 1. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 4, 2 resimden 2.
    • Unplug the battery from the motherboard.
  5. Acer TravelMate TMB115-M-C99B Touchpad Replacement, Hard Drive: adım 5, 3 resimden 1. Acer TravelMate TMB115-M-C99B Touchpad Replacement, Hard Drive: adım 5, 3 resimden 2. Acer TravelMate TMB115-M-C99B Touchpad Replacement, Hard Drive: adım 5, 3 resimden 3.
    • Carefully disconnect the hard drive from the motherboard.
  6. Acer TravelMate TMB115-M-C99B Touchpad Replacement, Motherboard: adım 6, 1 resimden 1.
    • Disconnect the two wires from the Wi-Fi interface.
  7. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 7, 2 resimden 1. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 7, 2 resimden 2.
    • Remove one 6mm Phillips screw from the Wi-Fi interface using the #0 screwdriver.
  8. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 8, 1 resimden 1.
    • Remove the Wi-Fi interface from the motherboard.
  9. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 9, 2 resimden 1. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 9, 2 resimden 2.
    • Remove the eight 7mm Phillips screws from the motherboard using the #0 screwdriver.
  10. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 10, 2 resimden 1. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 10, 2 resimden 2.
    • Remove the motherboard.
  11. Acer TravelMate TMB115-M-C99B Touchpad Replacement, Touchpad: adım 11, 1 resimden 1.
    • Remove one 6mm Phillips screw from the middle of the touchpad with the #0 screwdriver.
  12. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 12, 2 resimden 1. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 12, 2 resimden 2.
    • Remove the wire from the slot.
  13. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 13, 1 resimden 1.
    • Remove the stickers from the touchpad frame.
  14. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 14, 1 resimden 1.
    • Remove one 6mm screw from the corner of the touchpad frame with the #0 screwdriver.
  15. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 15, 2 resimden 1. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 15, 2 resimden 2.
    • Lift up the touchpad frame.
  16. Acer TravelMate TMB115-M-C99B Touchpad Replacement: adım 16, 1 resimden 1.
    • Remove the touchpad.
Sonuç
Tanvi Kharkar
334 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G5, White Winter 2019 Cal Poly, Team S1-G5, White Winter 2019 üyesi
CPSU-WHITE-W19S1G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 503
