Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Acer Travelmate 220 Disc Drive Replacement
Neye ihtiyacın var
  1. Acer Travelmate 220 Disc Drive Replacement, Disc Drive: adım 1, 1 resimden 1.
    • Flip your computer over so the bottom case is facing you.
  2. Acer Travelmate 220 Disc Drive Replacement: adım 2, 1 resimden 1.
    • Locate sliding unlock button near the AC power input.
  3. Acer Travelmate 220 Disc Drive Replacement: adım 3, 1 resimden 1.
    • Slide button in the direction of unlock and hold.
  4. Acer Travelmate 220 Disc Drive Replacement: adım 4, 1 resimden 1.
    • Gently pull the disk drive out.
  5. Acer Travelmate 220 Disc Drive Replacement: adım 5, 3 resimden 1. Acer Travelmate 220 Disc Drive Replacement: adım 5, 3 resimden 2. Acer Travelmate 220 Disc Drive Replacement: adım 5, 3 resimden 3.
    • With a small Phillips drive screwdriver, remove the 4 screws in sides of black plastic.
  6. Acer Travelmate 220 Disc Drive Replacement: adım 6, 2 resimden 1. Acer Travelmate 220 Disc Drive Replacement: adım 6, 2 resimden 2.
    • Pull off black plastic that covers the metal.
  7. Acer Travelmate 220 Disc Drive Replacement: adım 7, 1 resimden 1.
    • Locate green chip on back of drive.
  8. Acer Travelmate 220 Disc Drive Replacement: adım 8, 2 resimden 1. Acer Travelmate 220 Disc Drive Replacement: adım 8, 2 resimden 2.
    • Remove the 2 screws securing the green chip.
  9. Acer Travelmate 220 Disc Drive Replacement: adım 9, 1 resimden 1.
    • Firmly pull off green chip.
  10. Acer Travelmate 220 Disc Drive Replacement: adım 10, 1 resimden 1.
    • Insert green chip in new mechanism.
  11. Acer Travelmate 220 Disc Drive Replacement: adım 11, 3 resimden 1. Acer Travelmate 220 Disc Drive Replacement: adım 11, 3 resimden 2. Acer Travelmate 220 Disc Drive Replacement: adım 11, 3 resimden 3.
    • To reassemble your device, follow these instructions in reverse order
Sonuç
Bir başkası bu kılavuzu tamamladı.
Justin
62 İtibar
1 Kılavuz yazıldı
Ekip
UW Stout, Team 5-5, Zhou Fall 2011 UW Stout, Team 5-5, Zhou Fall 2011 üyesi
UWSTOUT-ZHOU-F11S5G5
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 4,736
