Ana içeriğe geç
Acer Travelmate 220 RAM Replacement
Neye ihtiyacın var
  1. Acer Travelmate 220 RAM Replacement, RAM Chip: adım 1, 1 resimden 1.
    • Place the computer with the bottom facing up.
  2. Acer Travelmate 220 RAM Replacement: adım 2, 3 resimden 1. Acer Travelmate 220 RAM Replacement: adım 2, 3 resimden 2. Acer Travelmate 220 RAM Replacement: adım 2, 3 resimden 3.
    • Locate the larger cover panel in the upper left hand corner of the computer.
    • Locate the Phillips screw holding the large cover panel in place.
  3. Acer Travelmate 220 RAM Replacement: adım 3, 2 resimden 1. Acer Travelmate 220 RAM Replacement: adım 3, 2 resimden 2.
    • Remove the located screw with the Phillips #00 screwdriver.
  4. Acer Travelmate 220 RAM Replacement: adım 4, 1 resimden 1.
    • Slide the large cover panel to the right, until you hear a click.
  5. Acer Travelmate 220 RAM Replacement: adım 5, 2 resimden 1. Acer Travelmate 220 RAM Replacement: adım 5, 2 resimden 2.
    • Place the plastic opening tool in the gap created to the left of the large cover panel.
    • Pry the cover panel up and remove it from the computer.
  6. Acer Travelmate 220 RAM Replacement: adım 6, 2 resimden 1. Acer Travelmate 220 RAM Replacement: adım 6, 2 resimden 2.
    • Locate the white plastic levers on each side of the two RAM chips.
  7. Acer Travelmate 220 RAM Replacement: adım 7, 3 resimden 1. Acer Travelmate 220 RAM Replacement: adım 7, 3 resimden 2. Acer Travelmate 220 RAM Replacement: adım 7, 3 resimden 3.
    • Locate the first RAM chip.
    • Push the plastic levers away from the first RAM chip.
  8. Acer Travelmate 220 RAM Replacement: adım 8, 3 resimden 1. Acer Travelmate 220 RAM Replacement: adım 8, 3 resimden 2. Acer Travelmate 220 RAM Replacement: adım 8, 3 resimden 3.
    • Lift the RAM chip from the compartment.
    • Repeat steps 7 and 8 to replace the second RAM chip.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kevin A
55 İtibar
1 Kılavuz yazıldı
Ekip
UW Stout, Team 5-5, Zhou Fall 2011 UW Stout, Team 5-5, Zhou Fall 2011 üyesi
UWSTOUT-ZHOU-F11S5G5
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 3,363
