Giriş
After about a year of intensive usage, I noticed the battery was swollen. I don't know whether it was caused by lying on it, storing it where it was bumped by other stuff, or just bad luck, but I figured this was repairable.
Neye ihtiyacın var
Just like when charging the device, take out the Bluetooth module from the headband and disconnect it from the speakers.
The back cover is glued in place. It's not a very tough glue, so the cover may have already shifted a bit from its place, and it shouldn't be too hard to remove.
The module has two compartments, one for the battery and one for the circuit board. Remove both from their rubbery shell.
You may be able to cleanly remove the two wires from the beige clip, but I wasn't confident I would be able to reconnect them, so I cut them near the battery, so I had plenty of wire to attach the new battery to.
The original battery is a prismatic LiPo 3.7 V 330mAh with dimensions 4x28x26 mm
I wasn't able to find one of that exact size, but since it fit even in its swollen state, I figured I could go for a thicker 6x28x23 mm battery
Solder or twist together the old and new battery wires
Cover the exposed parts with electrical tape
You can test your repairs without replacing everything into its protective cover first. This can save you some frustration when it doesn't work on the first try, but requires a bit more caution when handling the circuit board.
Long press the central button on the circuit board to turn it on. Does the red LED blink on?
Does it connect to your device?
Attach the speakers and try to play some audio
Attach a charger. Does the charging light come on?
You can look at the opening for the USB port to check the orientation (this is one place where USB-C would be a disadvantage)
It might take some patience to guide the wires through the opening between the two compartments. In my case it was easier to turn the battery sideways.
In my case, it remained sticky enough to not require new glue, even after several disassemblies.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I ended up removing the bad battery connector altogether from the battery wires. Then I soldered the negative side to the capacitor just below the connector on the board, and the positive side to the positive pin in the board connector. Finally I managed to get some glue gun glue on it.
