Ana içeriğe geç
Adding images to an existing answer
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
  1. Adding images to an existing answer, Adding images to an existing answer: adım 1, 3 resimden 1. Adding images to an existing answer, Adding images to an existing answer: adım 1, 3 resimden 2. Adding images to an existing answer, Adding images to an existing answer: adım 1, 3 resimden 3.
    • To get into the Edit window, click the "Edit" link
    • The edit window is now open. Click on the orange "Images" tab in the bottom left corner
    • This opens an approximately quarter screen size window with am upload symbol. This particular window may be empty, or it may have multiple images already present. This depends on if one has previously posted images. This is where the images are stored until they are going to be posted.
  2. Adding images to an existing answer: adım 2, 3 resimden 1. Adding images to an existing answer: adım 2, 3 resimden 2. Adding images to an existing answer: adım 2, 3 resimden 3.
    • To open the import image dialog, click the "Upload Icon", this will open up a upload dialog window. From here images can be either placed into the question, by "drag&drop", only if they are already in the image repository. Most of the time it will require using the "Browse Files" icon. .
    • When it is clicked on, it will access the users computer and list the directories. Choose the directory that contains the image to be imported. It is possible to select multiple images at once. Hold the "Ctrl" key down and left click on individual image files allow for this.
    • Once the file(s) is selected, click the "open" key. This will now upload the file to the image repository. Once the file(s) is uploaded, it will show in the repository.
  3. Adding images to an existing answer: adım 3, 3 resimden 1. Adding images to an existing answer: adım 3, 3 resimden 2. Adding images to an existing answer: adım 3, 3 resimden 3.
    • With the file showing in the bottom window, left click and hold on the image. Then drag the image into the question text window. This action will be noticeable since the background of the edit text window changes. Release the left mouse button once the cursor is in the question text window.
    • The image will be placed at the last cursor position. Ensure that the cursor is, where the image is supposed to be placed, before dragging it into the question text box.
    • Once the image is dragged to the question, it will show up as a number in the edit text box, but can be viewed in the preview. The image will now have been removed out of the repository as well.
    • Close the upload image window by clicking on the orange "Image" tab. If the position of the image, as well as the rest of the edit is satisfactory, click the orange "Submit revision" tab. This will post the edited answer with the image.
Sonuç
Hope this helps, good luck
6 farklı kişi bu kılavuzu tamamladı.
oldturkey03
782.052 İtibar
119 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
33 Üyeler
536 adet Kılavuz yazıldı
2 Yorum
Thanks for a much needed guide addition! Great work!
mayer - Yanıt
Thanks oldturkey for helping me upload pics really easy.
Gina, Sept 13
Gina - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 12,483
