Ana içeriğe geç
Adjusting Contrast on TI-Nspire Calculator
  1. Adjusting Contrast on TI-Nspire Calculator, Adjusting Contrast on TI-Nspire Calculator: adım 1, 2 resimden 1. Adjusting Contrast on TI-Nspire Calculator, Adjusting Contrast on TI-Nspire Calculator: adım 1, 2 resimden 2.
    • Remove the front protective cover by sliding it off of the calculator.
    • Press the "ON" button to turn on the calculator.
  2. Adjusting Contrast on TI-Nspire Calculator: adım 2, 3 resimden 1. Adjusting Contrast on TI-Nspire Calculator: adım 2, 3 resimden 2. Adjusting Contrast on TI-Nspire Calculator: adım 2, 3 resimden 3.
    • Press the "2ND" button at the top left portion of the keypad. An arrow pointing up will appear at the top left corner of the screen.
    • Press and hold the "UP" arrow until you have increased the contrast to a level that is easily visible for yourself. A common level to set the contrast is 5.
    • To decrease the contrast, press the "2ND" button, then press and hold the "DOWN" arrow.
Sonuç
Now you should have the image contrast set to your preferences.
Bir başkası bu kılavuzu tamamladı.
Alan Wong
63 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-52, Forte Fall 2012 Cal Poly, Team 7-52, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G52
5 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 5,995
