Ana içeriğe geç
Adjusting Nishiki Aero II Seat
Neye ihtiyacın var
  1. Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: adım 1, 3 resimden 1. Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: adım 1, 3 resimden 2. Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: adım 1, 3 resimden 3.
    • Loosen the bolt that secures your seat.
    • To do so, use one wrench to hold the larger nut on the left side of the bike still while you loosen the nut on the right.
  2. Adjusting Nishiki Aero II Seat: adım 2, 2 resimden 1. Adjusting Nishiki Aero II Seat: adım 2, 2 resimden 2.
    • Now that it can move, move the seat by wiggling it and pulling it in the direction you want to adjust it.
    • You want to the adjust the seat so that, when a pedal is at the far end of its rotation, your leg is fully extended.
    • Don't worry about getting it perfect on the first try. Instead, guess your adjustment, tighten the bolt a little bit, try it out, and adjust again until you get it right.
  3. Adjusting Nishiki Aero II Seat: adım 3, 1 resimden 1.
    • Once your seat is at the desired height, you just tighten the bolt the same way you loosened it.
    • Use two wrenches, one to hold it still and the other to tighten the nut.
    • Make sure it's very tight, or else the seat might twist or lower over time.
Sonuç
Tobias Elder
113 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-53, Johann Spring 2013 Cal Poly, Team 21-53, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G53
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 29
Her zaman: 2,778
