Giriş
The Smart Roadster front bonnet can misbehave and not close completely when lowering it, having to apply a lot of force to completely close it. In this simple guide I will show you how to adjust the closing mechanism so that it will close completely with minimal force applied.
Neye ihtiyacın var
Open the bonnet from the inside of the car (use the lever in the glove-box) and raise the bonnet completely open.
The 13mm screw used to adjust the closing mechanism of the bonnet. This is the one that probably needs adjustment
Screws which secure the mechanism to the bonnet
Spring which raises the bonnet slightly so that it can be further opened by hand
Use the 13mm Wrench to screw/unscrew the bonnet closing mechanism so that it gets adjusted. Usually it needs unscrewing a little so that it reaches the closing mechanism on the car.
The missing black paint on the screw indicates how much this bonnet closing mechanism needed adjustment
After adjustment the front bonnet should fully close easily when lowering.
3 farklı kişi bu kılavuzu tamamladı.
