Ana içeriğe geç
Adjusting the front bonnet
Neye ihtiyacın var
  1. Adjusting the front bonnet, Locate the closing mechanism on the bonnet: adım 1, 1 resimden 1.
    • Open the bonnet from the inside of the car (use the lever in the glove-box) and raise the bonnet completely open.
    • The 13mm screw used to adjust the closing mechanism of the bonnet. This is the one that probably needs adjustment
    • Screws which secure the mechanism to the bonnet
    • Spring which raises the bonnet slightly so that it can be further opened by hand
  2. Adjusting the front bonnet, Adjust closing mechanism using the screw: adım 2, 1 resimden 1.
    • Use the 13mm Wrench to screw/unscrew the bonnet closing mechanism so that it gets adjusted. Usually it needs unscrewing a little so that it reaches the closing mechanism on the car.
    • The missing black paint on the screw indicates how much this bonnet closing mechanism needed adjustment
    • After adjusting, if unscrewing was needed and the closing mechanism screw shows unpainted parts it would be wise to spray-paint the area to protect from corrosion/rust in the future.
Sonuç
After adjustment the front bonnet should fully close easily when lowering.
3 farklı kişi bu kılavuzu tamamladı.
Dan Mihai Ile
186 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 4,584
