Ana içeriğe geç
Aerogarden Air Pump Replacement
Videoya Genel Bakış
  1. Aerogarden Air Pump Replacement, Aerogarden Air Pump: adım 1, 2 resimden 1. Aerogarden Air Pump Replacement, Aerogarden Air Pump: adım 1, 2 resimden 2.
    • Remove the water and seed pod container and set it aside.
  2. Aerogarden Air Pump Replacement: adım 2, 2 resimden 1. Aerogarden Air Pump Replacement: adım 2, 2 resimden 2.
    • Peel back the footpads at the bottom.
    • Unscrew the eight screws on the bottom to remove the base
  3. Aerogarden Air Pump Replacement: adım 3, 2 resimden 1. Aerogarden Air Pump Replacement: adım 3, 2 resimden 2.
    • Disconnect the wires for the lights so the base can be fully opened.
  4. Aerogarden Air Pump Replacement: adım 4, 2 resimden 1. Aerogarden Air Pump Replacement: adım 4, 2 resimden 2.
    • Remove the four screws holding the pump down
  5. Aerogarden Air Pump Replacement: adım 5, 2 resimden 1. Aerogarden Air Pump Replacement: adım 5, 2 resimden 2.
    • Cut the wires as close to the pump as possible, to preserve their length. The wire connections are covered with glue
    • Strip the plastic from about 1/8 inch of the wire ends.
    • On the circuit board, note which wire is positive, and which wire is negative.
  6. Aerogarden Air Pump Replacement: adım 6, 2 resimden 1. Aerogarden Air Pump Replacement: adım 6, 2 resimden 2.
    • Connect the wires to the new pump and solder them in or affix them with heat shrink tubing for wires. Well, the solder should be covered with the heat shrink tubing, as well, since it is a potentially wet environment.
  7. Aerogarden Air Pump Replacement: adım 7, 3 resimden 1. Aerogarden Air Pump Replacement: adım 7, 3 resimden 2. Aerogarden Air Pump Replacement: adım 7, 3 resimden 3.
    • Assemble in reverse order.
Sonuç
Jameslimon
145 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 19
Her zaman: 46
