Ana içeriğe geç
Afterglow Wireless PS3 Controller Button Replacement
Neye ihtiyacın var
  1. Afterglow Wireless PS3 Controller Button Replacement, Back Cover: adım 1, 2 resimden 1. Afterglow Wireless PS3 Controller Button Replacement, Back Cover: adım 1, 2 resimden 2.
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
    FixBot'a Sor
    Yorum Ekle
  2. Afterglow Wireless PS3 Controller Button Replacement, Button: adım 2, 2 resimden 1. Afterglow Wireless PS3 Controller Button Replacement, Button: adım 2, 2 resimden 2.
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
    FixBot'a Sor
    Yorum Ekle
  3. Afterglow Wireless PS3 Controller Button Replacement: adım 3, 1 resimden 1.
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. Afterglow Wireless PS3 Controller Button Replacement: adım 4, 2 resimden 1. Afterglow Wireless PS3 Controller Button Replacement: adım 4, 2 resimden 2.
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    • Set aside the mini-motherboards so you can access the main motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. Afterglow Wireless PS3 Controller Button Replacement: adım 5, 2 resimden 1. Afterglow Wireless PS3 Controller Button Replacement: adım 5, 2 resimden 2.
    • Pull both vibration motors straight up from their holding place.
    FixBot'a Sor
    Yorum Ekle
  6. Afterglow Wireless PS3 Controller Button Replacement: adım 6, 2 resimden 1. Afterglow Wireless PS3 Controller Button Replacement: adım 6, 2 resimden 2.
    • Unscrew the two 9mm Phillips #0 screws holding the motherboard to the controller front plate.
    FixBot'a Sor
    Yorum Ekle
  7. Afterglow Wireless PS3 Controller Button Replacement: adım 7, 2 resimden 1. Afterglow Wireless PS3 Controller Button Replacement: adım 7, 2 resimden 2.
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The buttons have mini-motherboards secured in place on the front plate. Carefully pull these out.
    FixBot'a Sor
    Yorum Ekle
  8. Afterglow Wireless PS3 Controller Button Replacement: adım 8, 3 resimden 1. Afterglow Wireless PS3 Controller Button Replacement: adım 8, 3 resimden 2. Afterglow Wireless PS3 Controller Button Replacement: adım 8, 3 resimden 3.
    • Pick up the controller front plate and carefully turn it over so that the buttons left in it will fall out.
    • You may want to flip it while holding it over a container so the buttons do not go bouncing away from your work space.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Aj Coello
1.164 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S19-G5, Hoffman Spring 2017 USF Tampa, Team S19-G5, Hoffman Spring 2017 üyesi
USFT-HOFFMAN-S17S19G5
4 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 20
Son 30 gün: 85
Her zaman: 2,683
