Ana içeriğe geç
Afterglow Wireless PS3 Controller Joystick Replacement
Neye ihtiyacın var
  1. Afterglow Wireless PS3 Controller Joystick  Replacement, Back Cover: adım 1, 2 resimden 1. Afterglow Wireless PS3 Controller Joystick  Replacement, Back Cover: adım 1, 2 resimden 2.
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
    FixBot'a Sor
    Yorum Ekle
  2. Afterglow Wireless PS3 Controller Joystick  Replacement, Joystick: adım 2, 1 resimden 1.
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
    FixBot'a Sor
    Yorum Ekle
  3. Afterglow Wireless PS3 Controller Joystick  Replacement: adım 3, 1 resimden 1.
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. Afterglow Wireless PS3 Controller Joystick  Replacement: adım 4, 2 resimden 1. Afterglow Wireless PS3 Controller Joystick  Replacement: adım 4, 2 resimden 2.
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    FixBot'a Sor
    Yorum Ekle
  5. Afterglow Wireless PS3 Controller Joystick  Replacement: adım 5, 3 resimden 1. Afterglow Wireless PS3 Controller Joystick  Replacement: adım 5, 3 resimden 2. Afterglow Wireless PS3 Controller Joystick  Replacement: adım 5, 3 resimden 3.
    • Firmly grip the joystick housing with your forefingers by the yellow squares.
    • Use your other hand to get a grip on the black plastic joystick and pull directly away from the housing.
    • This will take some force to remove.
    • Try not to use the motherboard for leverage because it is delicate.
    FixBot'a Sor
    Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Aj Coello
1.164 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S19-G5, Hoffman Spring 2017 USF Tampa, Team S19-G5, Hoffman Spring 2017 üyesi
USFT-HOFFMAN-S17S19G5
4 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 25
Son 30 gün: 148
Her zaman: 5,573
