Ana içeriğe geç
Aiptek DZO-V58N Image Sensor Replacement
Neye ihtiyacın var
  1. Aiptek DZO-V58N Image Sensor Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the battery compartment on the back of the camera. It is the panel with the plastic ridges for simple removal.
    • Slide the battery compartment cover down off of the camera body.
    FixBot'a Sor
  2. Aiptek DZO-V58N Image Sensor Replacement: adım 2, 1 resimden 1.
    • Pry up the battery from the bottom using a finger and remove the batter from the case.
    FixBot'a Sor
  3. Aiptek DZO-V58N Image Sensor Replacement, Lens Protector: adım 3, 1 resimden 1.
    • Remove the lanyard by pulling the grey lace through the black string loop.
    • Pull black string loop through the silver bracket.
    FixBot'a Sor
  4. Aiptek DZO-V58N Image Sensor Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to pry off the black control cover.
    • The face plates are glued, so use force to pry the face plates from the camera body.
    FixBot'a Sor
  5. Aiptek DZO-V58N Image Sensor Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to pry off the ridged back face plate and the black button.
    • The button is loose and should come off with little or no effort.
    FixBot'a Sor
  6. Aiptek DZO-V58N Image Sensor Replacement: adım 6, 1 resimden 1.
    • Use a plastic opening tool to pry off the silver face plate.
    FixBot'a Sor
  7. Aiptek DZO-V58N Image Sensor Replacement: adım 7, 3 resimden 1. Aiptek DZO-V58N Image Sensor Replacement: adım 7, 3 resimden 2. Aiptek DZO-V58N Image Sensor Replacement: adım 7, 3 resimden 3.
    • Open the USB cover to expose the small machine screw.
    • Use the Phillips #00 screwdriver to unscrew the six 0.5cm machine case screws (distributed around the camera body).
    • These small screws are easy to lose. Place the removed screws in an organized container to avoid losing them.
    FixBot'a Sor
  8. Aiptek DZO-V58N Image Sensor Replacement: adım 8, 1 resimden 1.
    • Pull off the side control panel.
    FixBot'a Sor
  9. Aiptek DZO-V58N Image Sensor Replacement: adım 9, 2 resimden 1. Aiptek DZO-V58N Image Sensor Replacement: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Flip open the screen by pulling the loose end of the screen away from the case.
    • Use tweezers to remove the two outside rubber dots to reveal the two 0.5cm machine screws.
    • Use the #00 Phillips Screwdriver to remove both screws.
    FixBot'a Sor
  10. Aiptek DZO-V58N Image Sensor Replacement: adım 10, 2 resimden 1. Aiptek DZO-V58N Image Sensor Replacement: adım 10, 2 resimden 2.
    • Pull the body apart from the bottom of device just enough to make space to remove the silver plastic strap holder.
    • Use tweezers to remove the silver plastic strap holder.
    • Use a plastic opening tool to pry off the lens protector.
    FixBot'a Sor
  11. Aiptek DZO-V58N Image Sensor Replacement, Lens: adım 11, 3 resimden 1. Aiptek DZO-V58N Image Sensor Replacement, Lens: adım 11, 3 resimden 2. Aiptek DZO-V58N Image Sensor Replacement, Lens: adım 11, 3 resimden 3.
    • Unscrew the two silver 0.5cm machine screws with the #00 Phillips screwdriver.
    • Lift off the lens protector housing.
    • Pull apart the two halves of the camera body.
    • Do not pull the two halves apart too far because the wires may detach.
    FixBot'a Sor
  12. Aiptek DZO-V58N Image Sensor Replacement: adım 12, 1 resimden 1.
    • Unscrew both black machine screws holding the lens in place with the #00 Phillips screwdriver.
    FixBot'a Sor
  13. Aiptek DZO-V58N Image Sensor Replacement: adım 13, 1 resimden 1.
    • Carefully remove the compressed springs underneath each of the two screws that were removed in the previous step.
    • Be careful not to lose the springs. The springs are in compression and will launch from the camera if not held onto.
    FixBot'a Sor
  14. Aiptek DZO-V58N Image Sensor Replacement: adım 14, 1 resimden 1.
    • Lift off the lens.
    FixBot'a Sor
  15. Aiptek DZO-V58N Image Sensor Replacement, Image Sensor: adım 15, 2 resimden 1. Aiptek DZO-V58N Image Sensor Replacement, Image Sensor: adım 15, 2 resimden 2.
    • Use the #00 Phillips Screwdriver to unscrew the 3 circuit board screws.
    • Slightly separate circuit board from plastic case by lifting the circuit board straight out.
    FixBot'a Sor
  16. Aiptek DZO-V58N Image Sensor Replacement: adım 16, 2 resimden 1. Aiptek DZO-V58N Image Sensor Replacement: adım 16, 2 resimden 2.
    • Unplug the image sensor from the circuit board.
    • Pull the image sensor straight out to avoid damage to the pin connectors.
    FixBot'a Sor
Sonuç
Zachary Yun
28 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-5, Forte Spring 2012 Cal Poly, Team 5-5, Forte Spring 2012 üyesi
CPSU-FORTE-S12S5G5
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 41
Her zaman: 1,060
