Ana içeriğe geç
Aiptek Pocket DVII 1.3M LCD Display Screen Replacement
Neye ihtiyacın var
  1. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement, Display Screen: adım 1, 3 resimden 1. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement, Display Screen: adım 1, 3 resimden 2. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement, Display Screen: adım 1, 3 resimden 3.
    • Remove the battery cover.
    • Remove the batteries.
  2. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: adım 2, 2 resimden 1. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: adım 2, 2 resimden 2.
    • Remove the sticky black dots.
    • Remove the three black 4mm screws from the flip screen. Use a Phillips head screw driver.
  3. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: adım 3, 1 resimden 1.
    • Using an opening tool, separate the cover from the screen.
    • The cover won't completely come off. This will happen in the next step.
    • Don't be afraid to use a little more force.
  4. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: adım 4, 1 resimden 1.
    • Using an opening tool remove the outside cover of the flip screen.
    • Move the cover towards the lens and then away from the screen.
  5. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: adım 5, 2 resimden 1. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: adım 5, 2 resimden 2.
    • With the cover off, push the brown locking mechanism up, so the picture cable can be remove.
    • You only need to unplug the bottom cable in the picture.
  6. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: adım 6, 1 resimden 1.
    • Remove the two black screws from the circuit board.
  7. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: adım 7, 1 resimden 1.
    • With the opening tool, pop up the screen assembly.
    • The screen is glued to the black cover. Use more force if needed.
  8. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: adım 8, 1 resimden 1.
    • As in step 5, push up the brown locking mechanism of the remaining cable.
    • Unplug the picture cable.
  9. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: adım 9, 1 resimden 1.
    • Turn the circuit board over and with a soldering gun remove the two wires on each end.
    • Use a screwdriver to pull the loosened wire away.
  10. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: adım 10, 1 resimden 1.
    • With the wires no longer holding the circuit board and screen together, remove and replace the broken screen.
Sonuç
Gyozo Aba Hivatal
561 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-4, Brown Winter 2015 USF Tampa, Team 6-4, Brown Winter 2015 üyesi
USFT-BROWN-W15S6G4
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 351
