Ana içeriğe geç
Aiptek Pocket DVII 1.3M LCD Speaker Replacement
Neye ihtiyacın var
  1. Aiptek Pocket DVII 1.3M LCD Speaker Replacement, Speaker: adım 1, 3 resimden 1. Aiptek Pocket DVII 1.3M LCD Speaker Replacement, Speaker: adım 1, 3 resimden 2. Aiptek Pocket DVII 1.3M LCD Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Remove the battery cover.
    • Remove the batteries.
  2. Aiptek Pocket DVII 1.3M LCD Speaker Replacement: adım 2, 1 resimden 1.
    • Unscrew the three 4mm screws from the battery side of the device. Use a Phillips screw driver.
  3. Aiptek Pocket DVII 1.3M LCD Speaker Replacement: adım 3, 1 resimden 1.
    • Remove the four screws from the back side.
  4. Aiptek Pocket DVII 1.3M LCD Speaker Replacement: adım 4, 2 resimden 1. Aiptek Pocket DVII 1.3M LCD Speaker Replacement: adım 4, 2 resimden 2.
    • Remove the sticky black cover dot.
    • Remove the hidden screw.
  5. Aiptek Pocket DVII 1.3M LCD Speaker Replacement: adım 5, 2 resimden 1. Aiptek Pocket DVII 1.3M LCD Speaker Replacement: adım 5, 2 resimden 2.
    • Remove the two screws from the top side of the device.
    • Remove the two screws from the bottom side of the device.
  6. Aiptek Pocket DVII 1.3M LCD Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the rear cover.
    • Be careful not to lose the spring inside.
  7. Aiptek Pocket DVII 1.3M LCD Speaker Replacement: adım 7, 1 resimden 1.
    • Pull back the front cover so that you can dislodge the side cover.
  8. Aiptek Pocket DVII 1.3M LCD Speaker Replacement: adım 8, 1 resimden 1.
    • Unfold the device and be careful not to tear the black and red power supply wires.
  9. Aiptek Pocket DVII 1.3M LCD Speaker Replacement: adım 9, 1 resimden 1.
    • Unplug and replace the speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Gyozo Aba Hivatal
561 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-4, Brown Winter 2015 USF Tampa, Team 6-4, Brown Winter 2015 üyesi
USFT-BROWN-W15S6G4
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 127
