Ana içeriğe geç
Air Blasters Tek Six Reload Slider Spring Replacement
Neye ihtiyacın var
  1. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: adım 1, 3 resimden 1. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: adım 1, 3 resimden 2. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: adım 1, 3 resimden 3.
    • Using a Phillips #00 screwdriver, remove the two 11.6 mm screws that hold the grey slider together
    • Remove grey slider from the main body of the blaster.
    FixBot'a Sor
    Yorum Ekle
  2. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: adım 2, 3 resimden 1. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: adım 2, 3 resimden 2. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: adım 2, 3 resimden 3.
    • Using a Phillips #00 screwdriver, remove the six 9 mm screws that secure the main body.
    FixBot'a Sor
    Yorum Ekle
  3. Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: adım 3, 3 resimden 1. Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: adım 3, 3 resimden 2. Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: adım 3, 3 resimden 3.
    • Using the plastic opening tools, carefully separate the main case of the blaster to expose the inside.
    FixBot'a Sor
    Yorum Ekle
  4. Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: adım 4, 3 resimden 1. Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: adım 4, 3 resimden 2. Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: adım 4, 3 resimden 3.
    • Carefully grab the metal pin keeping the air system and top spring, and slide it outwards. This will release the air system with the plunger completely.
    FixBot'a Sor
    Yorum Ekle
  5. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw holding the top spring to reload slider: adım 5, 2 resimden 1. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw holding the top spring to reload slider: adım 5, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the 7.5 mm Phillips #00 screw holding the top spring to the reload slider.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Alfredo Antolinez
347 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-1, Brown Fall 2014 USF Tampa, Team 3-1, Brown Fall 2014 üyesi
USFT-BROWN-F14S3G1
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 35
Her zaman: 854
