Ana içeriğe geç
Air Blasters Tek Six Trigger Replacement
Neye ihtiyacın var
  1. Air Blasters Tek Six Trigger Replacement, Remove screw of the grey slider: adım 1, 3 resimden 1. Air Blasters Tek Six Trigger Replacement, Remove screw of the grey slider: adım 1, 3 resimden 2. Air Blasters Tek Six Trigger Replacement, Remove screw of the grey slider: adım 1, 3 resimden 3.
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
    FixBot'a Sor
  2. Air Blasters Tek Six Trigger Replacement, Remove screws in main body: adım 2, 3 resimden 1. Air Blasters Tek Six Trigger Replacement, Remove screws in main body: adım 2, 3 resimden 2. Air Blasters Tek Six Trigger Replacement, Remove screws in main body: adım 2, 3 resimden 3.
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
    FixBot'a Sor
  3. Air Blasters Tek Six Trigger Replacement, Take the main body apart: adım 3, 3 resimden 1. Air Blasters Tek Six Trigger Replacement, Take the main body apart: adım 3, 3 resimden 2. Air Blasters Tek Six Trigger Replacement, Take the main body apart: adım 3, 3 resimden 3.
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
    FixBot'a Sor
  4. Air Blasters Tek Six Trigger Replacement, Remove the trigger: adım 4, 3 resimden 1. Air Blasters Tek Six Trigger Replacement, Remove the trigger: adım 4, 3 resimden 2. Air Blasters Tek Six Trigger Replacement, Remove the trigger: adım 4, 3 resimden 3.
    • Grab the orange trigger and without misplacing the other parts of the blaster, remove the trigger.
    FixBot'a Sor
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alfredo Antolinez
347 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-1, Brown Fall 2014 USF Tampa, Team 3-1, Brown Fall 2014 üyesi
USFT-BROWN-F14S3G1
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 58
Her zaman: 957
