Ana içeriğe geç
Air Blasters Tek Six Trigger Replacement
Neye ihtiyacın var
  1. Air Blasters Tek Six Trigger Replacement, Remove screw of the grey slider: adım 1, 3 resimden 1. Air Blasters Tek Six Trigger Replacement, Remove screw of the grey slider: adım 1, 3 resimden 2. Air Blasters Tek Six Trigger Replacement, Remove screw of the grey slider: adım 1, 3 resimden 3.
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Air Blasters Tek Six Trigger Replacement, Remove screws in main body: adım 2, 3 resimden 1. Air Blasters Tek Six Trigger Replacement, Remove screws in main body: adım 2, 3 resimden 2. Air Blasters Tek Six Trigger Replacement, Remove screws in main body: adım 2, 3 resimden 3.
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Air Blasters Tek Six Trigger Replacement, Take the main body apart: adım 3, 3 resimden 1. Air Blasters Tek Six Trigger Replacement, Take the main body apart: adım 3, 3 resimden 2. Air Blasters Tek Six Trigger Replacement, Take the main body apart: adım 3, 3 resimden 3.
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Air Blasters Tek Six Trigger Replacement, Remove the trigger: adım 4, 3 resimden 1. Air Blasters Tek Six Trigger Replacement, Remove the trigger: adım 4, 3 resimden 2. Air Blasters Tek Six Trigger Replacement, Remove the trigger: adım 4, 3 resimden 3.
    • Grab the orange trigger and without misplacing the other parts of the blaster, remove the trigger.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alfredo Antolinez
347 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-1, Brown Fall 2014 USF Tampa, Team 3-1, Brown Fall 2014 üyesi
USFT-BROWN-F14S3G1
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 666
