Ana içeriğe geç
Air Conditioning Thermostat Replacement
Neye ihtiyacın var
  1. Air Conditioning Thermostat Replacement, Turn Off the Power: adım 1, 3 resimden 1. Air Conditioning Thermostat Replacement, Turn Off the Power: adım 1, 3 resimden 2. Air Conditioning Thermostat Replacement, Turn Off the Power: adım 1, 3 resimden 3.
    • Before you begin, locate the circuit breaker switchboard for the housing unit.
    • Find the air conditioning breaker that’s typically labeled inside the breaker's panel cover.
    • Turn off the electrical breaker switch that supplies the air conditioning thermostat.
  2. Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: adım 2, 3 resimden 1. Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: adım 2, 3 resimden 2. Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: adım 2, 3 resimden 3.
    • Separate the thermostat casing off of the wall plate. It should come off easily using your hands, but a pair of pliers can be used if it's being stubborn.
    • Take a picture using your phone's camera of the color-coded wiring, so it will be easier to re-attach the wiring to the new thermostat.
  3. Air Conditioning Thermostat Replacement: adım 3, 3 resimden 1. Air Conditioning Thermostat Replacement: adım 3, 3 resimden 2. Air Conditioning Thermostat Replacement: adım 3, 3 resimden 3.
    • Use the Flathead 3/32" 2.5 mm Screwdriver to separate the color coded wiring.
    • Use the Phillips or flathead screwdriver to separate and un-wrap each of the color coded wires. (For example: notice the yellow wire)
    • Use the Phillips or flathead screwdriver depending on the type of model, to remove the Phillips #0 Plus screw, in order to remove the base plate.
  4. Air Conditioning Thermostat Replacement: adım 4, 3 resimden 1. Air Conditioning Thermostat Replacement: adım 4, 3 resimden 2. Air Conditioning Thermostat Replacement: adım 4, 3 resimden 3.
    • Remove the old base plate of the thermostat.
    • Screw in the new base plate of the Thermostat using the Phillips or flathead screwdriver to screw in the Phillips #0 Plus screw drive.
    • Using the screwdriver; reconnect the color-coded wring based on the photo taken with your camera. (For example: Notice the yellow wiring)
  5. Air Conditioning Thermostat Replacement: adım 5, 2 resimden 1. Air Conditioning Thermostat Replacement: adım 5, 2 resimden 2.
    • Use your fingers to wrap the copper around the terminal slots, Use your Flathead 3/32" 2.5 mm Screwdriver to tighten the terminal slots. (For example: Notice the yellow wiring)
    • Fasten the terminal slots using your Phillips Flathead 3/32" 2.5 mm Screwdriver.
  6. Air Conditioning Thermostat Replacement: adım 6, 2 resimden 1. Air Conditioning Thermostat Replacement: adım 6, 2 resimden 2.
    • Place the new thermostat casing over the base plate.
    • Snap on the thermostat casing.
  7. Air Conditioning Thermostat Replacement: adım 7, 3 resimden 1. Air Conditioning Thermostat Replacement: adım 7, 3 resimden 2. Air Conditioning Thermostat Replacement: adım 7, 3 resimden 3.
    • Locate the circuit breaker switchboard for the housing unit.
    • Locate the air conditioning electrical breaker switch.
    • Turn on the electrical breaker switch that the air conditioning thermostat supplies.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Genesis
163 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
ما هو السبب خروج علامت E3 في اسبلت westtin
السبلت ٣ طن عمودي
Hassan Alkanan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 2,157
