Ana içeriğe geç
Air Filter Replacement
  1. Air Filter Replacement, Filter: adım 1, 1 resimden 1.
    • Locate air filter grille
    • This is usually found near the thermostat
    • Some systems contain multiple filters
    • Not all duct systems have a filter grill. Some are filtered at the air handling appliance
    FixBot'a Sor
    Yorum Ekle
  2. Air Filter Replacement, Open the grill: adım 2, 2 resimden 1. Air Filter Replacement, Open the grill: adım 2, 2 resimden 2.
    • Pull out both latches so that they are perpendicular to the wall
    • Pull grill open from top center
    FixBot'a Sor
    Yorum Ekle
  3. Air Filter Replacement, Remove used filter: adım 3, 1 resimden 1.
    • Remove the dirty filter
    FixBot'a Sor
    Yorum Ekle
    • If you aren't sure if the filter is ready to be changed just remember this is what cleans the air you are breathing.
    • Never wash or reuse a disposable filter
    • Pleated filters remove more dirt from the air than fiberglass filters. But their density restricts the air flow more. This can create problems in some systems. Experiment with both and see which is best for you and your system.
    • Filters should be checked every 30 days on residential applications and every 15 days on commercial applications.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 34
Her zaman: 538
