Ana içeriğe geç
Air Hog Smash Bots Controller Motherboard Replacement
Neye ihtiyacın var
  1. Air Hog Smash Bots Controller Motherboard Replacement, Front Panel: adım 1, 2 resimden 1. Air Hog Smash Bots Controller Motherboard Replacement, Front Panel: adım 1, 2 resimden 2.
    • Take out your controller and access to the back of the controller.
  2. Air Hog Smash Bots Controller Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the screw on the battery lid. Using the Hex 4 socket and PH #0 bit, remove the 8 mm screw.
  3. Air Hog Smash Bots Controller Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the 2 AAA batteries.
  4. Air Hog Smash Bots Controller Motherboard Replacement: adım 4, 2 resimden 1. Air Hog Smash Bots Controller Motherboard Replacement: adım 4, 2 resimden 2.
    • Using the Hex 4 socket and PH #0 bit, remove the four 8 mm screws on the panel.
  5. Air Hog Smash Bots Controller Motherboard Replacement: adım 5, 2 resimden 1. Air Hog Smash Bots Controller Motherboard Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to disconnect the front and back parts of the panel.
    • Some of the internal components may be displaced when opening the controller.
  6. Air Hog Smash Bots Controller Motherboard Replacement, Controller Motherboard: adım 6, 2 resimden 1. Air Hog Smash Bots Controller Motherboard Replacement, Controller Motherboard: adım 6, 2 resimden 2.
    • Using the PH #0 bit, remove two 8 mm screws on the main board.
    • De-solder the LED wires from the motherboard.
    • Lift the motherboard with a spudger to remove it from the case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brittany Frecker
542 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Baechle Spring 2016 IUPUI, Team 1-1, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S1G1
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
Hi,
Remot controller doesn't work.
Because my son used it into water.
So what should I do for fix it?
Thanks.
Ali Hori - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 172
