Ana içeriğe geç
AirCard 770S Back Case Replacement
Neye ihtiyacın var
  1. AirCard 770S Back Case Replacement, Back Case: adım 1, 1 resimden 1.
    • Hold the device with an open corner available and facing you.
  2. AirCard 770S Back Case Replacement: adım 2, 1 resimden 1.
    • Using your finger, pry open any of the four corners of the back case of your AirCard 770S, until you see the back case disconnect from the device.
  3. AirCard 770S Back Case Replacement: adım 3, 1 resimden 1.
    • Lift open the back case and remove it from the device.
    • In order to put a new back case on, make sure to align the white nobs found on the back cover, so that you do not force the case on and cause any damage to the device.
Sonuç
Caitlin Little
437 İtibar
3 adet Kılavuz yazıldı
Ekip
Marist, Team S1-G2, Chaterdon Fall 2018 Marist, Team S1-G2, Chaterdon Fall 2018 üyesi
MARS-CHATERDON-F18S1G2
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 223
