Ana içeriğe geç
AirCard 770S Battery Replacement
Neye ihtiyacın var
    1. AirCard 770S Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Hold the device with an open corner available and facing you.
      FixBot'a Sor
      Yorum Ekle
    2. AirCard 770S Battery Replacement: adım 2, 1 resimden 1.
      • Using your finger, pry open any of the four corners of the back of your AirCard 770S, until you see the back case disconnect from the device.
      FixBot'a Sor
      Yorum Ekle
    3. AirCard 770S Battery Replacement: adım 3, 1 resimden 1.
      • Lift open the back case and remove it from the device.
      FixBot'a Sor
      Yorum Ekle
    4. AirCard 770S Battery Replacement: adım 4, 1 resimden 1.
      • With the bottom of the device (above the charging port) facing you, use your thumb nail to lift up the battery.
      FixBot'a Sor
      Yorum Ekle
    5. AirCard 770S Battery Replacement: adım 5, 1 resimden 1.
      • Once the battery is lifted up, use the rest of your hand to remove the battery out from the device.
      • To put the battery back in to the device, make sure to align the "gold stripes" on the side of the battery to where they correspond in the base of the device, and align the backing to reassemble to device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Caitlin Little
437 İtibar
3 adet Kılavuz yazıldı
Ekip
Marist, Team S1-G2, Chaterdon Fall 2018 Marist, Team S1-G2, Chaterdon Fall 2018 üyesi
MARS-CHATERDON-F18S1G2
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 1,609
