Ana içeriğe geç
AirPods Battery Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. AirPods Battery Replacement, This reviews a 'first try', the actual guide begins on step 8!: adım 1, 3 resimden 1. AirPods Battery Replacement, This reviews a 'first try', the actual guide begins on step 8!: adım 1, 3 resimden 2. AirPods Battery Replacement, This reviews a 'first try', the actual guide begins on step 8!: adım 1, 3 resimden 3.
    • Using our tools, we pried open the bottom (silver tip) of our AirPod.
    • The second and third images show what you should accomplish.
    FixBot'a Sor
    Yorum Ekle
  2. AirPods Battery Replacement: adım 2, 3 resimden 1. AirPods Battery Replacement: adım 2, 3 resimden 2. AirPods Battery Replacement: adım 2, 3 resimden 3.
    • Next: Detailed disassembly of charging contact parts at the base of the battery.
    FixBot'a Sor
    Yorum Ekle
  3. AirPods Battery Replacement: adım 3, 3 resimden 1. AirPods Battery Replacement: adım 3, 3 resimden 2. AirPods Battery Replacement: adım 3, 3 resimden 3.
    • We continued disassembly as shown.
    FixBot'a Sor
    Yorum Ekle
  4. AirPods Battery Replacement: adım 4, 3 resimden 1. AirPods Battery Replacement: adım 4, 3 resimden 2. AirPods Battery Replacement: adım 4, 3 resimden 3.
    • We heated the AirPod to make battery removal easier. The heat softens the adhesive.
    • Do not overheat; the battery may explode.
    • Excess heat, particularly on a faulty battery, may indeed cause it to catch fire or even explode.
    FixBot'a Sor
    Yorum Ekle
  5. AirPods Battery Replacement: adım 5, 3 resimden 1. AirPods Battery Replacement: adım 5, 3 resimden 2. AirPods Battery Replacement: adım 5, 3 resimden 3.
    • You can see here that on the first try to remove the battery, the antenna components were pulled out, damaging them.
    FixBot'a Sor
    Yorum Ekle
  6. AirPods Battery Replacement: adım 6, 3 resimden 1. AirPods Battery Replacement: adım 6, 3 resimden 2. AirPods Battery Replacement: adım 6, 3 resimden 3.
    • Here you can see that the negative terminal of the battery is connected from the top to the base of the charging board, and the inner surface of the antenna is glued to the battery.
    FixBot'a Sor
    Yorum Ekle
  7. AirPods Battery Replacement: adım 7, 3 resimden 1. AirPods Battery Replacement: adım 7, 3 resimden 2. AirPods Battery Replacement: adım 7, 3 resimden 3.
    • For your reference: Close-up views of the original parts of the AirPods after completely removing the battery.
    FixBot'a Sor
    Yorum Ekle
  8. AirPods Battery Replacement: adım 8, 3 resimden 1. AirPods Battery Replacement: adım 8, 3 resimden 2. AirPods Battery Replacement: adım 8, 3 resimden 3.
    • Well! The official AirPods disassembly and battery replacement begins here. After heating, we will use a scalpel to pry open the bottom charging and microphone board.
    FixBot'a Sor
    Yorum Ekle
  9. AirPods Battery Replacement: adım 9, 2 resimden 1. AirPods Battery Replacement: adım 9, 2 resimden 2.
    • As you take it out, be careful of the short length and delicacy of the microphone lead, don't break it. Gently remove it. Then carefully clean the adhesive with fine-tip forceps or plastic tweezers and cotton bud wet with your solvent.
    • The Zippo lighter fluid is an excellent solvent for adhesives, but OBVIOUSLY: IT IS HIGHLY FLAMMABLE!
    FixBot'a Sor
    Yorum Ekle
  10. AirPods Battery Replacement: adım 10, 3 resimden 1. AirPods Battery Replacement: adım 10, 3 resimden 2. AirPods Battery Replacement: adım 10, 3 resimden 3.
    • With your syringe draw up a small amount (about 3/10ths C. C. or 0.3 ml) of the Zippo fuel to dissolve and clean the adhesive inside.
    • Though not mentioned in the tools, you can alternatively use the 3M adhesive remover/solvent in the photo.
    FixBot'a Sor
    Yorum Ekle
  11. AirPods Battery Replacement: adım 11, 3 resimden 1. AirPods Battery Replacement: adım 11, 3 resimden 2. AirPods Battery Replacement: adım 11, 3 resimden 3.
    • Prepare the required disassembly and soldering tools.
    • Firmly secure the AirPod.
    • Tin the tip of your iron, then add a small amount of solder. This makes for faster heat conduction, which makes it easier to remove the bottom battery lead. (and helps to avoid overheating the battery)
    FixBot'a Sor
    Yorum Ekle
  12. AirPods Battery Replacement: adım 12, 3 resimden 1. AirPods Battery Replacement: adım 12, 3 resimden 2. AirPods Battery Replacement: adım 12, 3 resimden 3.
    • These are close-up views while disconnecting the negative lead from the battery.
    FixBot'a Sor
    Yorum Ekle
  13. AirPods Battery Replacement: adım 13, 3 resimden 1. AirPods Battery Replacement: adım 13, 3 resimden 2. AirPods Battery Replacement: adım 13, 3 resimden 3.
    • Reposition the AirPod as shown, and bend the connector to better access the positive terminal. We will repeat the steps to de-solder the positive lead with a soldering iron.
    FixBot'a Sor
    Yorum Ekle
  14. AirPods Battery Replacement: adım 14, 3 resimden 1. AirPods Battery Replacement: adım 14, 3 resimden 2. AirPods Battery Replacement: adım 14, 3 resimden 3.
    • Close-ups of positive electrode disconnection.
    FixBot'a Sor
    Yorum Ekle
  15. AirPods Battery Replacement: adım 15, 3 resimden 1. AirPods Battery Replacement: adım 15, 3 resimden 2. AirPods Battery Replacement: adım 15, 3 resimden 3.
    • Use the syringe you drew up earlier to inject the solvent around the outside of the battery. Wait for the (foamed rubber?) adhesive to soften.
    FixBot'a Sor
    Yorum Ekle
  16. AirPods Battery Replacement: adım 16, 3 resimden 1. AirPods Battery Replacement: adım 16, 3 resimden 2. AirPods Battery Replacement: adım 16, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to wiggle the antenna glued on the outside of the battery left and right, then reapply the solvent.
    • Next we will insert a thin, piece of plastic between the battery and the inner surface of the antenna, vertically, to loosen and separate the battery and antenna.
    FixBot'a Sor
    Yorum Ekle
  17. AirPods Battery Replacement: adım 17, 3 resimden 1. AirPods Battery Replacement: adım 17, 3 resimden 2. AirPods Battery Replacement: adım 17, 3 resimden 3.
    • Next, heat the upper area of the outer casing of the earphone with a heat gun to soften the adhesive foamed rubber on the inside. After heating, inject the Zippo solvent again. Finally, use the hook and pliers to slowly pull the battery out.
    FixBot'a Sor
    Yorum Ekle
  18. AirPods Battery Replacement: adım 18, 3 resimden 1. AirPods Battery Replacement: adım 18, 3 resimden 2. AirPods Battery Replacement: adım 18, 3 resimden 3.
    • At last the battery is perfectly removed, you can see the bottom of the charging and microphone board and antenna leads in the AirPod.
    FixBot'a Sor
    Yorum Ekle
  19. AirPods Battery Replacement: adım 19, 3 resimden 1. AirPods Battery Replacement: adım 19, 3 resimden 2. AirPods Battery Replacement: adım 19, 3 resimden 3.
    • Prepare to replace the old battery. Ready the adhesive sticker backing by cutting it to the appropriate size.
    FixBot'a Sor
    Yorum Ekle
  20. AirPods Battery Replacement: adım 20, 3 resimden 1. AirPods Battery Replacement: adım 20, 3 resimden 2. AirPods Battery Replacement: adım 20, 3 resimden 3.
    • Insert the cut piece of backing paper between the battery lead and the antenna cable to facilitate battery insertion and to reduce friction.
    FixBot'a Sor
    Yorum Ekle
  21. AirPods Battery Replacement: adım 21, 3 resimden 1. AirPods Battery Replacement: adım 21, 3 resimden 2. AirPods Battery Replacement: adım 21, 3 resimden 3.
    • Then use the old battery that you removed to push the new battery down into place.
    • Next, solder the positive electrode of the battery.
    • Be careful not to apply heat for too long a time: Solder it quickly, (Remember tinning your iron and adding a bit of solder to the terminal first allow faster heat transfer—so do that) otherwise it will damage the battery.
    FixBot'a Sor
    Yorum Ekle
  22. AirPods Battery Replacement: adım 22, 3 resimden 1. AirPods Battery Replacement: adım 22, 3 resimden 2. AirPods Battery Replacement: adım 22, 3 resimden 3.
    • Next we solder and secure the negative electrode of the battery.
    • We used B-7000 glue, but if you want a more secure bond (and thus make fixing it again impossible?) it is recommended to use ab glue or epoxy glue.
    FixBot'a Sor
    Yorum Ekle
  23. AirPods Battery Replacement: adım 23, 3 resimden 1. AirPods Battery Replacement: adım 23, 3 resimden 2. AirPods Battery Replacement: adım 23, 3 resimden 3.
    • Clamp the glued AirPods with the C-clamps, wait for the glue to set, (or increase the temperature to accelerate the glue setting).
    FixBot'a Sor
    Yorum Ekle
  24. AirPods Battery Replacement: adım 24, 1 resimden 1.
    • Install them, test charging, play some music, check the Bluetooth connection is stable, and finally, verify that they can be used for at least three hours.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Since the first-generation AirPods have been used for a long time, the left earbud now only lasts for less than 30 minutes. The right earbud was replaced after it was lost, so the battery performance between the two is very different. This imbalance has shortened overall usage time and affected normal use.
I recently found a broken left AirPod and, after testing, discovered that its battery and battery life were still intact. This led me to try swapping the battery by disassembling the old AirPods. After some trial and error, I successfully completed the battery replacement.
I’m sharing this tutorial so others can try it too. Hopefully, it will help anyone on iFixit or elsewhere who is dealing with similar issues.
19 farklı kişi bu kılavuzu tamamladı.
deng lei
3.459 İtibar
2 adet Kılavuz yazıldı
10Kılavuz Yorumları
Where I buy the battery for replacement, and how under what name?
Leandro Rojas - Yanıt Paylaş
I'm using a damaged headset, but the battery is good, and I took it out for repair.  If you want a brand new original, it is only available in certain channels in China.
Deng lei - Yanıt Paylaş
Where can i buy an airpods battery…???
My location is Bangladesh,Asia.
Can i buy airpods battery in online???
Sk Ezaz - Yanıt Paylaş
Hola amigo, excelente el tutorial, sabes donde puedo comprar la batería? he buscado en canales de china pero no encuentro… mil gracias, espero tu respuesta.
Josemaria Puerta - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 27
Son 7 gün: 140
Son 30 gün: 714
Her zaman: 77,741
