Giriş
教你尽可能无损伤的拆解airpods充电盒,主要是针对普通用户刚进水没多长时间的朋友,可以尝试用我这种方法拆解后,尽可能的在最短的时间内将,电池和内部电路板拆出来抢救,尽量挽回损失!或者以后电池寿命缩短可以用这方法拆解更换!
用手术刀,插入里面四周都要左右划动,让充电盒的连接部件充分松动,再翘出一条缝隙好,插入撬棍之类的工具
To separate this part, I took a pair of needle-nose plyers and stick the ends down towards the columns where the base of the air pods sit. Clamp the plyers together and slowly extract, and it will come out scratch free. Just be sure to use a cloth in between the teeth of the plyers to avoid scratching the plastic when you squeeze down.
Also note to not pull it out completely because you will rip other components apart.
松动后用金属撬棒,在两边同时用力撬出,然后注意排线将内部底座取出来,最后用热风枪加热,将内部的不锈钢固定铁环其取出
个人总结,aiepods充电盒拆解的意义主要是针对普通用户刚进水没多长时间的朋友,可以尝试用我这种方法拆解后,尽可能的在最短的时间内将,电池和内部电路板拆出来抢救,尽量挽回损失
清理干净后再用吹风机,加热吹干后,测试能确认正常使用,没问题后再用B7000胶水粘接牢固即可使用啦! 希望能对各位朋友有所帮助!
最后我想请问下ifixit拆解团队,现在起airpods可修复性为 0 的评分能否改一下了? ( ^_^ )
Nice disassembly tutorial - reasonable enough! Now can you assemble it?
51 farklı kişi bu kılavuzu tamamladı.
13 Yorum
So, just buy new AirPods then?
Haha thats exactly what this article tought me too :D
Sounds about right… ;-)
Way to much work.
Why was it English to some language?!
still looks like a “0” to me
thinks that helped me out it works know.
mis audífonos son clon pero igual la info me ayudó á abrirlos
