Giriş
The battery gives the device enough power to save the settings when the device is unplugged. The battery is a circular object that is located underneath the logic board.
Neye ihtiyacın var
Using a metal spudger, gently pry the cover off the bottom of the device.
To detach the small clips from the connectors, place the flat end of the plastic spudger underneath the clip and gently lever it away from the center of the device.
To detach the large clip from its connector, place the flat end of the spudger on the clip and lever it upward out of the connector.
Eight 10.25 mm T8 Torx screws secure the heat sink to the logic board. Unscrew all eight screws.
Remove the heat sinks from the logic board.
5 farklı kişi bu kılavuzu tamamladı.
6 Yorum
im assuming the small battery gives some sort of power to make the airport function correctly
I’ve opened quite a lot of broken A1521 and always checked the battery. None of them worked with a new battery or due to the “reset”
Sorry…
Hi, my AE doesn’t flash the ethernet leds when I connect it to the power supply and it isn’t visible neither over wifi nor ethernet but the principal led changes from green to amber and finally flashes amber repeatedly. ¿some hint to fix it?. Thanks in advance.
does the small circular battery give the logic board any power cause I am having problems with a rapidly flashing amber light I just replaced power supply
