Giriş
The logic board is the main component of the device. It has all the major components for the device to function properly: USB ports, WLAN and LAN ports, and router chips. Because of the many functions the logic board performs, it requires a fan and heat sink to prevent it from overheating. This guide requires you to remove many small screws; use the magnetic mat to prevent losing these screws.
Using a metal spudger, gently pry the cover off the bottom of the device.
To detach the small clips from the connectors, place the flat end of the plastic spudger underneath the clip and gently lever it away from the center of the device.
To detach the large clip from its connector, place the flat end of the spudger on the clip and lever it upward out of the connector.
Eight 10.25 mm T8 Torx screws secure the heat sink to the logic board. Unscrew all eight screws.
Remove the heat sinks from the logic board.
5 farklı kişi bu kılavuzu tamamladı.
2 Comments
Nice teardown but where can you buy a replacement logic board?
Hi everyone! Can someone provide a more closer picture of the 2 connectors that goes to the fan and to led. I accidentally broke those 2 small connectors and i was trying to solder them back. A more closer picture of the zone would help me a lot.
