Ana içeriğe geç
Airox Legendair Battery Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Airox Legendair Battery Replacement, How to Properly Clean the Airox Legendair: adım 1, 1 resimden 1.
    • First, switch off the device.
    • Place the device in a clean and open environment.
  2. Airox Legendair Battery Replacement: adım 3, 1 resimden 1.
    • Using a cloth or a sponge slightly dampened with a bactericide or germicide solution, gently clean the outside of the device.
  3. Airox Legendair Battery Replacement: adım 4, 1 resimden 1.
    • If necessary, spray the device lightly with the germicide solution, taking account of the requirements discussed in the preliminary operations.
    • Do not allow any liquid to enter inside the device (in particular through the cooling apertures).
    • Use a gentle air blast to clear away any remaining liquid from ventilator.
  4. Airox Legendair Battery Replacement, Battery: adım 6, 1 resimden 1.
    • Make sure to turn off the ventilator before starting the repair.
    • Before you start the battery replacement process, make sure that the device has been placed in a clean and open environment.
  5. Airox Legendair Battery Replacement: adım 7, 1 resimden 1.
    • Remove each attachment screw from the battery cover.
  6. Airox Legendair Battery Replacement: adım 8, 1 resimden 1.
    • Remove the battery cover carefully by holding the rails and pulling toward the rear of the device.
  7. Airox Legendair Battery Replacement: adım 9, 1 resimden 1.
    • Extract the current battery and replace it with the new battery.
  8. Airox Legendair Battery Replacement: adım 10, 1 resimden 1.
    • Confirm that all elements line up together. Then, reattach the battery cover with the attachment screws that were removed in Step 2.
  9. Airox Legendair Battery Replacement: adım 11, 1 resimden 1.
    • Switch the device to "Set Up Mode" by pressing the On/Off switch.
    • Hold the menu key until the menu options appear on the screen.
    • Select the "MAINTENANCE" option with cursor.
    • Select "Voltage control" and verify that the voltage of the battery is 28.5±1V.
Sonuç
Perform the final inspection procedures by confirming that every screw is secure before putting back into service.
Caleb Erlenborn
174 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G15, Paton Spring 2020 Cal Poly, Team S7-G15, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G15
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 402
