Ana içeriğe geç
Akai MPK25 Beat Pad Replacement
Neye ihtiyacın var
  1. Akai MPK25 Beat Pad Replacement, Face Plate: adım 1, 1 resimden 1.
    • Remove all the selector knob covers by pulling them off.
    FixBot'a Sor
    Yorum Ekle
  2. Akai MPK25 Beat Pad Replacement: adım 2, 1 resimden 1.
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
    FixBot'a Sor
    Yorum Ekle
  3. Akai MPK25 Beat Pad Replacement: adım 3, 1 resimden 1.
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
    FixBot'a Sor
    Yorum Ekle
  4. Akai MPK25 Beat Pad Replacement: adım 4, 3 resimden 1. Akai MPK25 Beat Pad Replacement: adım 4, 3 resimden 2. Akai MPK25 Beat Pad Replacement: adım 4, 3 resimden 3.
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
    FixBot'a Sor
    Yorum Ekle
  5. Akai MPK25 Beat Pad Replacement: adım 5, 3 resimden 1. Akai MPK25 Beat Pad Replacement: adım 5, 3 resimden 2. Akai MPK25 Beat Pad Replacement: adım 5, 3 resimden 3.
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
    FixBot'a Sor
    Yorum Ekle
  6. Akai MPK25 Beat Pad Replacement, Beat Pad: adım 6, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the thirteen 9.8 mm silver screws holding the mother board to the face plate.
    FixBot'a Sor
    Yorum Ekle
  7. Akai MPK25 Beat Pad Replacement: adım 7, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the four 9.8mm screws holding in the base of the beat pad.
    FixBot'a Sor
    Yorum Ekle
  8. Akai MPK25 Beat Pad Replacement: adım 8, 2 resimden 1. Akai MPK25 Beat Pad Replacement: adım 8, 2 resimden 2.
    • Slightly lift the mother board near the edge of the beat pads and wiggle the beat pad ribbon connector free.
    FixBot'a Sor
    Yorum Ekle
  9. Akai MPK25 Beat Pad Replacement: adım 9, 2 resimden 1. Akai MPK25 Beat Pad Replacement: adım 9, 2 resimden 2.
    • Remove the beat pad sensor from the face plate.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Serbinder Singh
81 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-6, Maness Winter 2013 Cal Poly, Team 20-6, Maness Winter 2013 üyesi
CPSU-MANESS-W13S20G6
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 38
Her zaman: 4,620
