Giriş
Use this guide if any of the selector knobs get bent, broken, or stops working.
Neye ihtiyacın var
Using a Phillips #2 screwdriver, remove the thirteen 9.8mm silver screws holding the mother board to the face plate.
Flip the mother board back over so the potentiometers are facing down and the leads are facing up. Then identify which leads correspond to the broken potentiometer.
Use a soldering iron with solder wick (or a solder sucker) in order to free the potentiometer from the mother board.
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Thanks for putting together this great tutorial. Does anybody out there have the part number of the potentiometer?
There’s NO need to remove all of the knobs in Steps 1 & 2…the faceplate lifts off with or without them attached.
NY Prince - Yanıt
