Ana içeriğe geç
Akai Retro Boom CD player model CE2200 Speaker Replacement
Neye ihtiyacın var
  1. Akai Retro Boom CD player model CE2200 Speaker Replacement, Speaker: adım 1, 3 resimden 1. Akai Retro Boom CD player model CE2200 Speaker Replacement, Speaker: adım 1, 3 resimden 2. Akai Retro Boom CD player model CE2200 Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Remove the batteries located under the radio by sliding open the removable panel.
  2. Akai Retro Boom CD player model CE2200 Speaker Replacement: adım 2, 3 resimden 1. Akai Retro Boom CD player model CE2200 Speaker Replacement: adım 2, 3 resimden 2. Akai Retro Boom CD player model CE2200 Speaker Replacement: adım 2, 3 resimden 3.
    • Use a six inch Phillips #2 screwdriver to remove the screws that hold the clamshell body together.
    • There will be six (6) screws at the bottom of the speaker, one (1) screw in the CD player, and two (2) under the battery panel. A total of nine (9) screws.
    • Each screw is 12.7 millimeters.
  3. Akai Retro Boom CD player model CE2200 Speaker Replacement: adım 3, 3 resimden 1. Akai Retro Boom CD player model CE2200 Speaker Replacement: adım 3, 3 resimden 2. Akai Retro Boom CD player model CE2200 Speaker Replacement: adım 3, 3 resimden 3.
    • Use the plastic spudger or the Jimmy to gently pry open the plastic shell halves from each other.
    • The red boxes highlight the speakers you are replacing.
    • Be careful of loose wiring when prying the halves open.
  4. Akai Retro Boom CD player model CE2200 Speaker Replacement: adım 4, 2 resimden 1. Akai Retro Boom CD player model CE2200 Speaker Replacement: adım 4, 2 resimden 2.
    • Unplug the small red connector from the circuit board.
    • Be firm with your pinch and pull gently.
  5. Akai Retro Boom CD player model CE2200 Speaker Replacement: adım 5, 2 resimden 1. Akai Retro Boom CD player model CE2200 Speaker Replacement: adım 5, 2 resimden 2.
    • Carefully remove the speakers from their placeholders by lifting each speaker up.
    • Set removed speakers aside and recycle them later.
  6. Akai Retro Boom CD player model CE2200 Speaker Replacement: adım 6, 2 resimden 1. Akai Retro Boom CD player model CE2200 Speaker Replacement: adım 6, 2 resimden 2.
    • Insert new speakers where the old ones were located
    • Then connect the new speakers to the circuit board.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Charlotte Kong
148 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 328
