Giriş
This is a guide to replacing the up and down buttons on your Akaso EK7000. Required tools are: a metal spudger or any other instrument used to pry or separate, and a Phillips #000 screwdriver.
Neye ihtiyacın var
Locate the battery cover at the bottom of the camera. Use your fingers to gently pry open the battery cover.
Using the metal spudger, gently pry open the front panel from the exposed battery cartridge.
Using a Phillips #000 screwdriver, remove the four screws securing the cover plate.
2 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Annie, where do I get the replacemnet bottons for the Akaso 7000 pro?
