Ana içeriğe geç
Akko MOD 007 v2 Keyboard Switch Replacement
Neye ihtiyacın var
  1. Akko MOD 007 v2 Keyboard Switch Replacement, Keyboard Switch: adım 1, 2 resimden 1. Akko MOD 007 v2 Keyboard Switch Replacement, Keyboard Switch: adım 1, 2 resimden 2.
    • Unplug the USB-C cable.
  2. Akko MOD 007 v2 Keyboard Switch Replacement: adım 2, 2 resimden 1. Akko MOD 007 v2 Keyboard Switch Replacement: adım 2, 2 resimden 2.
    • Flip the keyboard over so the backside is facing up.
    • Remove the three longer 20.2 mm screws using the T5 Torx screwdriver.
    • Remove the three 8 mm screws using the T5 Torx screwdriver.
  3. Akko MOD 007 v2 Keyboard Switch Replacement: adım 3, 2 resimden 1. Akko MOD 007 v2 Keyboard Switch Replacement: adım 3, 2 resimden 2.
    • Pull the front and back case apart.
    • If your keyboard is dirty, you’ll want to clean it before continuing. Use compressed air or a brush.
  4. Akko MOD 007 v2 Keyboard Switch Replacement: adım 4, 2 resimden 1. Akko MOD 007 v2 Keyboard Switch Replacement: adım 4, 2 resimden 2.
    • Insert the keycap puller horizontally on the keycap and pull up.
    • Excessive force may break the tool or keycaps so don't yank the keycap up.
  5. Akko MOD 007 v2 Keyboard Switch Replacement: adım 5, 2 resimden 1. Akko MOD 007 v2 Keyboard Switch Replacement: adım 5, 2 resimden 2.
    • Insert the switch puller vertically in the switch tabs and gently pull up.
  6. Akko MOD 007 v2 Keyboard Switch Replacement: adım 6, 3 resimden 1. Akko MOD 007 v2 Keyboard Switch Replacement: adım 6, 3 resimden 2. Akko MOD 007 v2 Keyboard Switch Replacement: adım 6, 3 resimden 3.
    • Orientate the new switch to align the pins to the board's sockets.
    • Push the switch down into the sockets.
    • Make sure the pins are aligned to sockets, as misalignment will cause the switch to be faulty.
Sonuç
Test the switch by opening a keyboard tester website, like 'keyboardtester.com,' and press the key to see if it activates.
Farhan
133 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 16
Son 30 gün: 53
Her zaman: 993
