Ana içeriğe geç
Alan 48 Excel: Reception problems? No problem!
Neye ihtiyacın var
      • First of all: Power off! Switch it off and unplug the device.
      • Then grab your screwdriver and undo the screws on the housing.
      • Carefully lift off the housing and put it to one side.
      FixBot'a Sor
      Yorum Ekle
      • Check all cables and connections. Are they properly seated?
      • Especially important: Check the connections to the antenna and the loudspeaker.
      FixBot'a Sor
      Yorum Ekle
      • Time for some contact spray and brushes! Spray the connections thoroughly.
      • Wait a few minutes, then wipe away the residue with a clean cloth.
      FixBot'a Sor
      Yorum Ekle
    1. Alan 48 Excel: Reception problems? No problem!, Check the transistor “Q104 (KTK 161)”: adım 4, 1 resimden 1.
      • Find the transistor “Q104 (KTK 161)” on the circuit board. Here it is:
      • Take your multimeter and check the transistor. If it is defective, it must be replaced.
      FixBot'a Sor
      Yorum Ekle
    2. Alan 48 Excel: Reception problems? No problem!, Replace transistor “Q104 (KTK 161)”: adım 5, 1 resimden 1.
      • In order to replace the transistor, carefully desolder the connections. This is where you need to start:
      • Insert the new transistor and solder it in place.
      • Check the connections with the multimeter to make sure that everything is properly working.
      FixBot'a Sor
      Yorum Ekle
      • Put the housing back on and tighten the screws.
      • Plug in the plug, switch on the device.
      • Test whether the reception is now better.
      FixBot'a Sor
      Yorum Ekle
Sonuç
That's it! With these steps, your Alan 48 Excel should have top reception again. If not, a major repair may be necessary.
3 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Ingo Bünnemeyer
248 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 38
Her zaman: 2,001
