Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Alber e-motion M15 Power Wheels cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Alber e-motion M15 Power Wheels Battery Rebuild, Opening Battery: adım 1, 3 resimden 1. Alber e-motion M15 Power Wheels Battery Rebuild, Opening Battery: adım 1, 3 resimden 2. Alber e-motion M15 Power Wheels Battery Rebuild, Opening Battery: adım 1, 3 resimden 3.
    • First you must remove the four circlips holding in the four plastic locking pegs. Pliers, as little bending as you can get away with, and waggling are your friend, you'll need to reuse them.
    • There are now four hollow through rivets that need to be dealt with. If you're lucky you can crunch the back side of these with pliers without having to tear off the padding foam around. If it's a struggle, remove the foam around, slide a spudger or razorblade underneath one side and you should be able to lift enough to squash them.
    • Remove the foam very gently, starting at one of the ends and working your way along the rim. It's not the end of the world if it tears but it's best if you can get it off in one piece without stretching and tearing it. You can try warming it a little with a gentle heat from a hairdryer if it's being stubborn but it should come off fairly easily.
    • Place foam to one side, it should be reusable without any extra adhesive.
    • With the rivets removed you should be able to slide a spudger into the rim of the lid and work it under and pop it off. There's no catches, just a uniform lip all around underneath. Be careful removing it because of the charging cable.
  2. Alber e-motion M15 Power Wheels Battery Rebuild, Removing Charging Cable.: adım 2, 2 resimden 1. Alber e-motion M15 Power Wheels Battery Rebuild, Removing Charging Cable.: adım 2, 2 resimden 2.
    • Pull gently holding the black part to remove the charging cable and put the lid to one side. Note the orientation (track side up) and the way it folds.
  3. Alber e-motion M15 Power Wheels Battery Rebuild, Removing Circuit Board.: adım 3, 3 resimden 1. Alber e-motion M15 Power Wheels Battery Rebuild, Removing Circuit Board.: adım 3, 3 resimden 2. Alber e-motion M15 Power Wheels Battery Rebuild, Removing Circuit Board.: adım 3, 3 resimden 3.
    • Desolder the battery tabs and mask them off with electrical tape. You will need to use a fairly large soldering iron tip due to the side of the pads. You may well find you need to use an (ideally non-conductive) tool to lift the tabs clear.
    • Once all the tabs are clear, masked, remove all the phillips head screws from the board (several of which I have managed to lose by the time the photograph was taken).
    • Carefully begin lifting the circuit board and the adhesive paper underneath as evenly as possible from all sides. Waggle it a little to begin to loosen it but not too much.
    • Take care whilst lifting as there are three thermistors going down amongst the cells from the board. and you do not want to damage them.
    • When the board is free, place it to one side.
  4. Alber e-motion M15 Power Wheels Battery Rebuild, Removing Old Cell Tabs.: adım 4, 3 resimden 1. Alber e-motion M15 Power Wheels Battery Rebuild, Removing Old Cell Tabs.: adım 4, 3 resimden 2. Alber e-motion M15 Power Wheels Battery Rebuild, Removing Old Cell Tabs.: adım 4, 3 resimden 3.
    • Take multiple pictures of your existing cell layout as you will need to recreate it exactly. (Now updated with two pictures from my other wheel battery rebuild without the clipped tab)
    • Pry off the old tabs (only if you know what you're doing. The risk of fire and explosion if you do not is very high. It's fully possible to learn but this guide is not where to do it.)
    • Unscrew the two security screws (circled). Place battery upside down. There are holes in the back of the pack you can poke a blunt tool into to help push the rubber cell holder but only push on the ones with white rubber visible. A preferable option is using a spring hook to lift under those circled areas and lift a little each side at a time.
    • Eventually you'll be able to remove the white cell holder.
  5. Alber e-motion M15 Power Wheels Battery Rebuild, Underside: adım 5, 2 resimden 1. Alber e-motion M15 Power Wheels Battery Rebuild, Underside: adım 5, 2 resimden 2.
    • Now is the best chance to take an indellible marker and write the polarity of every cell on the rubber of the holder.
    • Pry off remaining tabs. Maintain all safety precautions.
    • Cells will push out from bottom of holder. (The missing one was found in my coffee).
    • The cells inside were Model: LGEAMF11865 (ICR18650MF1). Capacity: 2150mAh Rated. Voltage: 3.65V Nominal. Charging: 4.20V Maximum 1075mA Standard
    • I chose to replace with: Manufacturer: Sanyo/Panasonic · Model: NCR18650GA · Size: 18650 · Capacity: 3500mAh · Maximum Discharge: 10A
    • Make sure to balance the cells by pre-charging them all. You require 21 so you be prepared to do it in advance.
  6. Alber e-motion M15 Power Wheels Battery Rebuild, Weld Cells: adım 6, 2 resimden 1. Alber e-motion M15 Power Wheels Battery Rebuild, Weld Cells: adım 6, 2 resimden 2.
    • Using a battery spot welder and at least 0.15mm pure nickel strips, recreate the original structure of the pack. (And do a better job than me... although in my defence I did clean up and reweld some of the tabs after this photo was taken.)
    • Complete the underside first, then place it into the battery tub. Remember to take care with the tabs that come off the bottom and secure them with kapton or electrical tape before placing it into the tub.
    • Please only attempt this if you know what you're doing and have practiced. If you have even the slightest doubts please seek advice/help.
    • Once you have completed the welds, replace the circuit board and its paper, taking care to line up the thermistors with the holes in the cell holder.
    • Put fresh solder on the the pads on the board then solder the battery tabs down on their corresponding pads. It may help to hold the pads down with a small screwdriver (taking great care not to touch another pad), then once the solder cools enough to hold the tab, heating the screwdriver tip with the soldering iron enough to remove it).
  7. Alber e-motion M15 Power Wheels Battery Rebuild, Closing Up.: adım 7, 3 resimden 1. Alber e-motion M15 Power Wheels Battery Rebuild, Closing Up.: adım 7, 3 resimden 2. Alber e-motion M15 Power Wheels Battery Rebuild, Closing Up.: adım 7, 3 resimden 3.
    • Reconnect the battery connector track side up.
    • Put lid back on battery, being careful not to trap the cable. Push closed all around.
    • At this point you can test the battery. The battery bolts will be annoying to lock in place without the rivets to guide them but it is possible. If you have a multimeter should hopefully get you two of the pairs of contacts giving roughly 12.5v each from fully charged cells.
    • Now the fun part... I never managed to find replacement rivets. If you can find 12mm(head)x8mm(outer)x7mm(inner)x10mm(long although you can cut down anything longer) rivets... you can use them.
    • If you can't... And because the rivets also act to guide the retaining bolts so make life a lot easier...
    • You do what I did and get 8mm copper/aluminium pipe with an inner wall of less than 0.5mm or (I used 0.25mm because it was half the price.
    • I then used a mini pipe cutter to cut approx 14mm lengths, used side cutters to cut a few 2-3mm cuts at each end, put it through the holes, and then bent those back like petals to make crude rivets.
    • Put the bolts back through the holes, put the circlips back on, bend the circlips so they retain the bolts again. Reapply your rubber seal. Sometimes it will be harder to insert the battery if you have to use the homemade rivets. This can be eased by replacing with a thinner good quality foam tape.
Mice Principal
145 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 43
Her zaman: 571
