Ana içeriğe geç
Alcatel Fierce 4 Front-Facing Camera Replacement
Neye ihtiyacın var
  1. Alcatel Fierce 4 Front-Facing Camera Replacement, Battery: adım 1, 1 resimden 1.
    • Using a plastic opening tool, pry the back cover off of the phone.
  2. Alcatel Fierce 4 Front-Facing Camera Replacement: adım 2, 2 resimden 1. Alcatel Fierce 4 Front-Facing Camera Replacement: adım 2, 2 resimden 2.
    • Remove the seventeen Phillips #000 screws from the mid-frame.
  3. Alcatel Fierce 4 Front-Facing Camera Replacement: adım 3, 1 resimden 1.
    • Pry off the mid-frame using a plastic opening tool, working your way around the perimeter.
  4. Alcatel Fierce 4 Front-Facing Camera Replacement: adım 4, 2 resimden 1. Alcatel Fierce 4 Front-Facing Camera Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to disconnect all of the cables on the motherboard.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
  5. Alcatel Fierce 4 Front-Facing Camera Replacement: adım 5, 1 resimden 1.
    • Remove the motherboard from the phone.
  6. Alcatel Fierce 4 Front-Facing Camera Replacement: adım 6, 1 resimden 1.
    • Carefully pry up the battery with a plastic opening tool, or your hands.
  7. Alcatel Fierce 4 Front-Facing Camera Replacement, Front-Facing Camera: adım 7, 3 resimden 1. Alcatel Fierce 4 Front-Facing Camera Replacement, Front-Facing Camera: adım 7, 3 resimden 2. Alcatel Fierce 4 Front-Facing Camera Replacement, Front-Facing Camera: adım 7, 3 resimden 3.
    • Use a plastic opening tool to pry up the camera connector from the motherboard.
    • Remove the camera.
Sonuç
Rawan
644 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Cagle Spring 2018 USF Tampa, Team S1-G2, Cagle Spring 2018 üyesi
USFT-CAGLE-S18S1G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 157
